Which parts / extra work is needed for clutch replacement?
Old Jul 29, 2003 | 04:51 PM
NYCe MaXiMa's Avatar
I have the pressure plate, disc and throw out bearing.
What else should be replaced while the mechanic is in there?
For some reason I ossumed that I need the "rear main seal" replaced and told him that, which he said is an extra 75$ due to some sort of modification or extra work required.
But I mixed it up, and what needs to be replaced is the "gasket" between the engine and tranny, correct? What is this thing called extactly?
Anything else that needs to be done? perhaps the axle seals? Car has well over 100k miles but I never had any leaks.
thank you
Old Jul 29, 2003 | 05:03 PM
Jeff92se's Avatar
I'm needing a caw
Pilot shaft bearing but I really doubt it. Never really wears out. Rear main seal would be a good idea. It's the seal that attached behind the flywheel. It's purpose is to keep the oil around the crankshaft from spilling out from that end of the engine. Same idea as the front crank shaft seal(right behind the crank pulley). Just the rear end version of it.
Remember to get the flywheel resurfaced properly.
Both axle seals should be changed. Cheap and easy to do. Check the cv joints, tie rods ends, lower ball joints.
Don't you want a Fidanza?? Damn good time to do this and I have them in stock.
Old Jul 29, 2003 | 05:12 PM
Thanks Jeff,
thanks for the offer I was waiting for you to make
Yes, I'd very much like a Fidanza but have to decide against it for now.
So I suppose the rear main seal is not a neccessity? But I should still have them change the gasket, right?
As far as axles, tie rod ends and lower ball joints.. I believe one of these things is bad as I get some slight knocking/pinging noise and feel it in the steering wheel as I ride over bumps.. can't be the struts and the other components on them as they are brand new.. I was hoping to check the parts you mentioned myself.. these things don't require as much work to change right?
Old Jul 29, 2003 | 05:44 PM
Jeff92se's Avatar
I'm needing a caw
Hmmm I would change the rear main seal to be safe. The suspension stuff should be alot easier to deal with as they are down there anyway
kenc15
Sep 25, 2015 06:38 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
TonyJr
Aug 20, 2015 12:14 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
kirkhilles
Aug 8, 2015 10:53 AM
