Does the 5th gen muffler bolt on to the 4th gen?
Old Feb 7, 2001 | 12:25 PM
1MAX2NV's Avatar
I need to get rid of my muffler. It's way too loud with Y-pipe, b-pipe and no cat. Anyone have one for sale? Or want to trade for my Stillen plus some cash?
Old Feb 7, 2001 | 01:33 PM
Jeff92se's Avatar
I'm needing a caw
Regardless of the muffler you use, it probably will NOT be bolt one. The biggest reason is that the new muffler will have to be welded on.
Now if you are running a catback of 2.5", the inlet of the 2000 max muffler is slightly smaller. So some fiddling will have to be done to get it to fit but I should not be a problem.
Noise. I don't run a resonator so you probably should not have to also. But you should make sure as to where the noise is coming from. If it's from under the shifter area, it's probably the flex section leaking. If it's from the rear of the car than yeah, the 2000 max muffler will do you just right.
Old Feb 7, 2001 | 04:25 PM
PIONEER's Avatar
Tony if your stillen will bolt on my 2k and not cause any problems then lets talk a deal, Shoot me a Emai. In class right now bit I'll check later on tonight. pi0neer@ibm.net
lowpost99
Oct 26, 2025 06:53 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
TheMafia
Sep 4, 2015 08:26 AM
Lowered_a33
Sep 1, 2015 07:49 PM
