QuesTion 4 Guys Who Know SysTems
Old Feb 7, 2001 | 07:02 PM
tunedup's Avatar
MTX Blue thunder amp 350 MAX 2 Channels.
12" pioneer sub 400W
is the sub and amp goood????
run with the stock bose setup and deck
how would it be
can i run it with the stock setup ???
i am payin 120 canadian for it
Old Feb 7, 2001 | 08:25 PM
Maxstilln's Avatar
If your looking to power a sub you should look into a mono block amp, they are designed just to power subwoofers. As far as using your Bose system, I would recomemend a JBL Power valve amp. Its a mono block and the high level input has the same sound quality as using the line level rca plugs. With the Bose system you'd have to buy a PAC converter and there is a signal loss and clarity loss. The JBL will sound great and its built for subs. As far as woofers go the Pioneer is a nice woofer, how much do you want to spend and what are you attempting to acheive, ie SQ SPL etc.
1995 1st Place NOPI Nationals 2000
Old Feb 7, 2001 | 08:28 PM
tunedup's Avatar
I just want somehtin
decent
not like competition merchandise
as far as the bose system goes
i like it i just want more bass a bit more punch ...
without spending an arm and a leg..
thxn bro for your help.
Old Feb 7, 2001 | 08:29 PM
turbolaw99's Avatar
Set the gain low on the amp and use a sealed enclosure to complement but not overpower the Bose. Otherwise all you'll hear is the low end. As far as quality, make due with your good deal, but JL Audio subs offer a balance between power controlled output.
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 17, 2016 04:54 AM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
