Another potentially silly question (prolly not)
Old Aug 12, 2003 | 03:21 PM
nupe500's Avatar
Jedi Knight
is it possible to put the factory sunroof into a car that did not come with one from the factory? Are the cars structurally different in the roof? anyone ever take a gander to know?
Old Aug 12, 2003 | 03:25 PM
Jeff92se's Avatar
I'm needing a caw
I don't think so. In my 3gen, you can see some additional sheet metal there when you open the roof. I suppose if you got some serious talent with a welder. OR if you happen to have that part w/o the sunroof(but I really doubt it)
Old Aug 12, 2003 | 03:37 PM
nupe500's Avatar
Jedi Knight
thanks all knowing Jeff!
Old Aug 12, 2003 | 03:57 PM
EZEMaxima's Avatar
i asked a body shop once and they said, they can graft the roof on made with the support and mounting brackets for the sunroof. Or locate a donor car from a junk yard and swap the roof part....they said it's like replacing your quarter panels... cut of the part and weld in the new part....basically a R&R if you have the correct parts..
Old Aug 12, 2003 | 04:50 PM
nupe500's Avatar
Jedi Knight
too bad you're in Hawaii...there's a guy who says he can do it here...but I'm skeptical...u know? we'll see...reason I ask is that some is interested in buying it but I was already thinking about this and wanted to see how feasible it was.
Thanx
Old Aug 12, 2003 | 05:26 PM
Frank Fontaine's Avatar
Re: Another potentially silly question (prolly not)
After watching Discovery and TLC, anything is possible. Even if you had the resources to do so, I don't think the results are worth the effort. Just buy a 95 SE with moonroof for 3 grand, and you can have an entire car for probably less that what it'd cost to cut off your roof and install another one.
Old Aug 12, 2003 | 06:30 PM
BioMaxDDS's Avatar
I had a sunroof put into my 3000GT back in 97, never had any problem with it. i think it cost around $1k
Old Aug 12, 2003 | 07:04 PM
Infinitbird's Avatar
My moms 2001 gxe didn't have a sunroof from the factory but the dealer put one in for her so i think its very possible.
Old Aug 12, 2003 | 08:28 PM
Dave Holmes's Avatar
I would be leery about the structural integrity of a roof that has had a hole cut in it without factory reinforcement. Now I could be way off base, but here is my reasoning. A post on this board said that a sunroof equipped Maxima is 65 lbs heavier than the identical car without one. I've removed my sunroof glass, and seen the motor, etc... I can not see how that would add up to near 65 lbs. This makes me believe that there is significant strengthening of the roof. Plus, I think if there wasn't, and the car rolled, there would be a huge liability for the manufacturer when the roof caves in compared to a non-sunroof equipped model. It's not like the safety glass will be supportive, because it won't be intact.
If it was me, and I didn't have a sunroof but wanted one, I'd get a car from the factory with one. I just don't think it would be worth the expense/hassle to have one installed (not to mention possible air/water leaks).
Those are my thoughts, and they could be wrong...
Dave
Old Aug 13, 2003 | 05:09 AM
deezo's Avatar
A lot of work dude...
Old Aug 13, 2003 | 12:28 PM
nupe500's Avatar
Jedi Knight
I have decided that I'm not even going to put any sunroof in the car...just deal without it...my first car without a sunroof...I've been so spoiled!..
Old Aug 13, 2003 | 01:20 PM
deezo's Avatar
Now you won't have to worry about fixing it when it goes bad.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Dec 12, 2015 09:39 AM
Socalstillen
Sep 26, 2015 12:01 PM
