Are there any stiffer exhaust hangers on the market for the Max?
Old Aug 13, 2003 | 10:20 AM
deezo's Avatar
After dropping my ride, the stock hangers allow my exhaust to swing all over the place when on bumpy roads. How are you guys getting around this issue?
Old Aug 13, 2003 | 10:35 AM
Chunger's Avatar
My other car is a Hybrid
Try inserting a fuel hose into the space inside the rubber hanger and maybe 2 larger wire ties thru the hose to keep it there and stiffen it. And/Or you can go to a muffler shop and have them weld in another hanger just in front of the rear wheel. I had to do both of these because my SP muffler and 130mm tip is within 1/4" bumper cutout.
Old Aug 13, 2003 | 10:51 AM
deezo's Avatar
Thank you sir!
Old Aug 13, 2003 | 12:30 PM
ericdwong's Avatar
Theres poly ones that are made for Subaru, last time i checked i think they would fit.
Old Aug 13, 2003 | 01:17 PM
deezo's Avatar
Any links?
Old Aug 13, 2003 | 03:47 PM
EteRnity059's Avatar
Boosted?....
Originally posted by deezo
Any links?
I had the same problem with my exhaust hanging too low. I just changed all of the hangers with new rubber hangers. They worked great. It was a B$$$h to get the one near the cat. I had to use my jack to lift up the pipe in order to hang it. The o2 sensor also digs in to some metal plates so I had to be careful not to jack up the pipe too much. As for the results, no more scratching of my pipes on speed bumps.
Old Aug 13, 2003 | 05:26 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
U should use hose clamps and clamp the rubber hangers so it won't let your exhaust swing everywhere.
Old Aug 14, 2003 | 10:49 AM
araffio's Avatar
That's what I did too
-Tony
Old Aug 14, 2003 | 11:17 AM
deezo's Avatar
I just zip tied it for now. Let's see how that holds up.
Old Aug 14, 2003 | 11:28 AM
araffio's Avatar
Should be fine
Old Aug 14, 2003 | 01:16 PM
robocop199's Avatar
auto zone sells rubber exhaust hangers that are really stiff and they're the same size as OEM.
Old Aug 14, 2003 | 08:08 PM
Titleistprov21's Avatar
How can you guys see your exhaust wiggle? Someone behind you tell you? I always laugh at the hondas w/ fart cans that wiggle, but if mine does that too then i feel like an idiot.
Old Aug 14, 2003 | 08:11 PM
96shogunmax's Avatar
My greddy swings on bumpy roads and hits the hanger behind the cat and makes a Thump! noise . I hate that. The B pipe part of it hangs really low too.
Old Aug 14, 2003 | 08:29 PM
Jon91SE's Avatar
Pusssseeeehhhh
Have you tried a local exhaust shop? I had my hangers custom made that way.
Old Aug 14, 2003 | 08:31 PM
Made what way? How many did you add?
Old Aug 15, 2003 | 05:31 AM
deezo's Avatar
You can hear it shaking and you can move it by shaking it.
Old Aug 15, 2003 | 06:58 AM
Mishmosh's Avatar
Subaru
Any links?
http://www.subarupower.com/karexhan.html
I know I've seen 'em for $7-8 though...
Old Aug 15, 2003 | 07:21 AM
deezo's Avatar
Thanks. Now that I know what to look for, I'll search for a better price.
Old Aug 15, 2003 | 08:09 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i have the same thing with mine. swaying back and forth. it cant be cool ! im going to leave the play in it. (having a sarona rear bumper installed) then after the install im going to use some of these suggestions to stop the sway , which cant be cool !
Old Aug 15, 2003 | 08:51 AM
deezo's Avatar
This leads me to think that this is part of the issue with flex sections goin bad on y-pipes.
Old Aug 15, 2003 | 12:29 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I bought a set. Waste of money. The diameter of the holes cast into the kartboy polyurethane insulators are too big. The exhaust moved around just as much as it with the rubber insulators. Best bet is to have your local muffler shop weld in a sturdy hanger on the pipe above the axle and/or have them heat and bend the existing hangers (down).
Here's a pic
Old Aug 15, 2003 | 01:07 PM
deezo's Avatar
I'll cancel my order then. I just need to fix the hangers around the resonator. I think one broke when I drove over some crap in the road at 90 mph. It sounded like metal or some other hard material when it hit.
dvcamp
Sep 18, 2015 10:17 AM
Maxie40
Sep 14, 2015 11:28 AM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
