I'm looking for some vital info, and I need the Maxima guru's help...
Old Oct 1, 2003 | 02:06 PM
tampamax's Avatar
The following info is what i'm trying to find out. And PLEASE, if you don't know or are not sure then please refrain from posting.
This is for the 3.0VQde, 95-99 and 00-01:
bore?
stroke?
compresion ratio?
intake valve head diameter?
intake port dimensions?
exhaust valve head diameter?
exhaust port dimensions?
model # of intake and exhaust cams?
lifter type?
intake lift at valve?
intake rocker arm ratio?
intake duration @ .050 degrees lift?**
intake lobe centerline?
intake opens @ _____^BTDC?
intake closes @ _____^ABDC?
exhaust lift at valve?
exhaust rocker arm ratio?
exhaust duration @ .050 degrees lift?**
exhaust lobe centerline?
exhaust opens @ _____^BBDC?
exhaust closes @ _____^ATDC?
^ means degree
** means if duration @ .050 degree lift is unknown, specify at what lift duration is measured
Thanks for looking and your help guys.
Old Oct 1, 2003 | 02:13 PM
Jeff92se's Avatar
I'm needing a caw
I think if you want 100% reliable info, invest in a Nissan FSM for the VQ30??
Old Oct 1, 2003 | 02:29 PM
ivelweyz
there are some threads about this also, so look for them...
Old Oct 2, 2003 | 08:14 AM
tampamax's Avatar
Ok, let me rephrase the question. Does anyone with an FSM want to help me out and give this a try?
Old Oct 5, 2003 | 12:04 PM
tampamax's Avatar
TTT...Does anyone want to help out?
Goffery2uned
Aug 21, 2015 09:50 PM
Turbobink
Aug 15, 2015 07:20 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
