HELP just got TransGo kit, need help with $hitty instructions..
Old Feb 15, 2001 | 04:19 PM
sinewave's Avatar
This has got to be the worst set of instructions I have ever seen.
Whoever has just installed this, I sure could use any advice and warnings you would care to share.
Old Feb 15, 2001 | 10:15 PM
bigtexan7's Avatar
Honestly, I thought the instructions to be pretty straightforward. It's a pretty big job, if they make no sense at all to you, better take it to a shop to be installed.
Old Feb 16, 2001 | 04:57 AM
JJW95SC's Avatar
How much did the kit cost you including shipping?
Jim
Old Feb 16, 2001 | 05:39 AM
RussMaxManiac
That's what you pay for when you only spend $50 on a crappy kit.
Old Feb 16, 2001 | 06:51 AM
Mike S.'s Avatar
Russ.....
Why do you call it a crappy kit? Do YOU have one? But you probably know someone who does right. In case you didn't know the trans go kit is all the parts to upgrade the VB....but you do the labor yourself. Don's is probably simmilar but he's doing the labor. GET IT? Steve C from Chicago has this same kit in his 4th gen auto S/C thats running....ummm..low 13's. But yea....the kits crappy cuz you say so.
Old Feb 16, 2001 | 06:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Russ.....
yes Russ makes ignorant comments on something he doesn't know about. the instructions are very straight forward..best to go to a shop.
Old Feb 16, 2001 | 08:07 AM
sinewave's Avatar
bigtexan7
I have never been past the filter of an a/t, but I've rebuilt 3 manual trannies, so I think I can handle this.
Maybe once I have the vb apart, things will be clearer. I guess some of the things that concern me are:
1. Instructions on page 1 indicate the placement of 5 steel *****. It says do not use plastic *****. Are the existing ***** plastic and do I need to buy some check ***** before I tear down the vb?
2. Is the template for drilling the main plate to scale?
3. How did you drill the 3/64" hole in the valve body? Did you drill it at an angle from the right?
4. Why is the line solenoid shown on page 2? Is there any work to be done to it?
Old Feb 16, 2001 | 08:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: bigtexan7
1. there should be steel *****..if they are plastic then replace them w/ steel *****. they provide a few to you. actually i don't think check ***** are plastic for the maxima.
2. they give u the EXACT (range) measurement
to drill. follow that range.
3. you drill into the plate between the two halves of the VB. drill straight. it's like punching a hole in the sheet metal.
4. last i check the solenoids were attached to the VB. you may want to replace them if your tranny high mileage. make sure you get new O rings and etc.
someone correct me if i'm wrong here...but it looks straight forward.
Old Feb 16, 2001 | 08:44 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Re: bigtexan7
Turbo95Max, Candiman, and I did a 3rd gen last weekend. Let me see if I can answer some of your questions...
1) The steel ***** should've came with your kit.
2) Follow what drill bit they say to use.
3) Candiman called TransGo and they told him he can drill from any angle and as long as it goes through, it should be fine.
4) No idea... need to see a picture.
Make sure you keep track of what bolt goes in where because they are different lengths. Good luck!
Old Feb 16, 2001 | 09:46 AM
sinewave's Avatar
I guess my biggest concerns were the hole to be drilled in the vb and the steel *****. The pictures in the instructions are great, I just expected more detailed written instructions.
Thanks guys. I appreciate your help.
Old Feb 16, 2001 | 11:22 AM
bigtexan7's Avatar
1. Not to worry, all check ***** inside my 4th gen were steel. you can reuse them without problem.
2. Template is almost to scale. When you have it in front of you, it will be clear.
3. Yes, I drilled it at an angle from the right.
4. I think the solenoid was just there for orientation sake. Check to see that o-rings are intact when you reinstall.
Old Feb 16, 2001 | 11:26 AM
bigtexan7's Avatar
A HELPFUL TIP:
Before you reinstall the VB, squirt trans fluid in and around all valves and work them back and forth by hand a little. When you open it up, all fluid is lost and I wiped mine dry to make it easier to work with. Just make sure you lube it back up before reinstalling otherwise you may have to drive around for a while to get them to break open so the car will shift.
Old Feb 16, 2001 | 11:49 AM
sinewave's Avatar
Thanks BigTexan7
I don't know if I will get to install it this week-end, it's the start of Mardi Gras here. I'll drink a beer in your honor!
Old Feb 16, 2001 | 01:44 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: bigtexan7
Kev did u take pics?? wanna do mine?? too damn lazy to crack mine open. huge difference? how's the shift quality?
Old Feb 16, 2001 | 03:19 PM
Y2KevSE's Avatar
Re: Re: Re: bigtexan7
No pics because we didn't have a camera... and our hands were greasy. The difference isn't as huge as Don's VB mod. I've participated in the TransGo kit and have witnessed Don's recalibration process from start to finish... I have to say that they are two totally different processes.
I've never taken a ride in Candiman's 3rd gen before, so I can't say the shifts improved or not. When we took a test drive, he said he noticed a difference, but the hard shifts won't really come out until VB is broken in.
Want us to do your VB? Hmmmm... maybe?
Old Feb 16, 2001 | 03:23 PM
MardiGrasMax's Avatar
Re: Thanks BigTexan7
Yea Baby!!!!
I just quit my job too, so its beer time!!! I did get a much better one, and dont start till March 5th. So let the Gras begin!!!
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
