Do camber plates eliminate the strut bearings?
Old Oct 23, 2003 | 10:02 PM
1FSTMAX's Avatar
I'm pretty sure they do.
Old Oct 23, 2003 | 10:21 PM
matt calder's Avatar
wrong reason to be buying $300 camber plates.
Old Oct 23, 2003 | 10:22 PM
1FSTMAX's Avatar
http://forums.maxima.org/showthread....=camber+plates
Old Oct 24, 2003 | 05:26 AM
ejj's Avatar
ejj
No, they don't. You still need the factory strut bearings.
Old Oct 24, 2003 | 06:01 AM
stephenlc's Avatar
How low is too low before you need camber plates and how can you adjust the camber without camber plates. I know ours are no adjustable but is there another solution?
Old Oct 24, 2003 | 06:30 AM
BEJAY1's Avatar
Conecarver
Ecentric or crash bolts are available from many suppliers. Problem is you gotta take the wheel off, adjust the bolt, remount the wheel, and take the alignment measurement (camber, toe, etc). If it's not right then back to step 1.
Plates make it much easier.
Old Oct 24, 2003 | 09:45 AM
Originally Posted by slammed95
Why's that? I never said I wasn't gonna use them for the adjustable camber and to eliminate play with the spherical bearing.
I know what these things do, I'm just unsure if they replace the strut bearing. If they do need a strut bearing then I'll get the JIC's.
Still the wrong reason?
Good glad you know.
Buy JIC's they are worth it.
Old Oct 24, 2003 | 11:03 AM
1MAX2NV's Avatar
NO...You will need your OEM strut bearings.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
