how much $ should I offer for used stillen lip?(pic)
Old Feb 19, 2001 | 06:32 PM
mikez's Avatar
First off this is a stillen front lip right?
How much should I offer this salvage yard for it(if it is not cracked)?
I've searched the forum and found you can get a new one for $140-180.
Would 65-70 be to low?
thanks
Old Feb 19, 2001 | 06:48 PM
ereet's Avatar
It looks pretty beat up,
but at 60 bucks that's a really good deal. The side panels were shaped like "L"'s when I got them, and I was able to mold them back with a heat gun.. With a lot of heat, patience and tape/vicework to hold it straight, you should be able to straighten it out. I wouldn't pay more than 80 for it, especially if you can't work on it without cracking the paint.
Old Feb 19, 2001 | 07:02 PM
metallic97gxe's Avatar
Master Will
it is.............
not worth getting it at all unless you want this recked one that bad there will be more aggrevation and headache trying to get it back straight and mabye be more time and money just right just buy a better one....get the Focal F5's though they are tight you might get them for $60.00......
Old Feb 19, 2001 | 07:19 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
just save and get a new one...not worth the hassle imo...
Old Feb 19, 2001 | 08:07 PM
1MAX2NV's Avatar
Looks pretty good to me. Looks like he rear ended->
an SUV. The front lip look like it's just got few scratchs.
Old Feb 19, 2001 | 08:24 PM
JDwyer2821's Avatar
Re: Looks pretty good to me. Looks like he rear ended->
just looks like the whole front end is bent not the lip. Looks good to me too!
Old Feb 19, 2001 | 08:26 PM
got rice?'s Avatar
You have to consider that since it's already painted, it'll take some more time to strip and prep the surface to be painted again (if his car is a different color).
Old Feb 19, 2001 | 08:31 PM
JDwyer2821's Avatar
He can strip and prep that himself.
Old Feb 19, 2001 | 09:03 PM
NickStam's Avatar
What state are those liscense plates?
Old Feb 19, 2001 | 09:45 PM
Kevin Wong's Avatar
Looks Fine
It looks like the front end is crooked not the just the lip. If the yard is local, just go try and fit it on your car.
Old Feb 19, 2001 | 10:59 PM
DaBoxSE's Avatar
I like the Rims! How much would those go for?!
Old Feb 20, 2001 | 01:35 PM
BlkCat
If you don't have clear front corner lamps you should also check them out to see if they're salvagable, if you don't already have them.
Btw the lip look ok to me from that angle.
Old Feb 20, 2001 | 01:59 PM
Jeff92se's Avatar
I'm needing a caw
Take the lip off to see if it goes back to the original shape somewhat. If it's still pretty bent, you gonna have a hard time coaxing back into the correct shape. If the paint underneath is sticking well, there's no need to strip the old stuff off.
t6378tp
Sep 29, 2018 04:27 PM
Stagnet04
Sep 14, 2015 11:28 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
