need help with ap brakes!!!!!!!!! URGENT!!!!!!!
i was trying to bleed the calipers and then the bolt snapped and after i took out te remainder of the bolt the thread inside the caliper totally messed up...
i can take the caliper to the machine shop and the new threads machined, but then i dont know where to find a new bolt that would fit into the hole cuz after i machine it the whole would be at least a little biggger.
any suggestions??
any suggestions??
Originally Posted by slammed95
So you broke the bleeder valve? A machine shop might be able to enlarge the hole and insert a threaded plug so you can use the same size bleeder.
You might need to get a new caliper from Stillen. I don't even wanna know what they cost, considering the outer part of the rotors cost $300 a piece!
Good luck, and let us know what happens.
i would have to get a new caliper???? i hope not.....
i know the machine shop can enlarge the hole but then i have to find a larger bleeder bolt to fit into it... anyone know what kind of cars have bigger bleeder bolts so i can machine the hole according the that bolt???
Originally Posted by Maximam
Heli-coil!
Get it drilled out, rethreaded for a heli-coil. Problem solved and original bleeder used.
and i would wanna know where i can get the original bleeder... cuz the thread on the original bleeder is done too
call up AP racing and tell them what you've done. this isn't something to rig back together.
some companies offer larger bleeder screws as replacements when stuff like this happens.
others say to use heli-coils. others say to TIG weld the hole closed and re-drill it.
others say to send it to them and they will do the repairs.
Call AP before you do anything else on your own.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
