Need low end boost (advice)
Old Feb 24, 2001 | 02:12 PM
Carlos A's Avatar
Greetings,
I have installed a Stillen Y, JWT Pop charger, soon a High Flow CAT and haver reset my ECU and while I see the gains at the high end of the power band I am still avid for power at the low end.
I know I could change the flywheel to an Aluminum one (there might be some complications), change my clutch to one form a Z (there might be an engagement mismatch with the aluminum flywheel). I could change my ECU to a JWT or UDP one but I think this only gives me gains over 3000 rpm (I would be already at 60 or 70 mph).
I am truly looking to improve the low end from 0 to 60 (need that acceleration).
Any advice?
Thanks guys,
Old Feb 24, 2001 | 10:53 PM
NightRider's Avatar
S-AFC ir similar ECU should do the trick.
Old Feb 24, 2001 | 10:57 PM
emax02's Avatar
Thats funny because with my car,
I have more then enough power on the low end. If I had any more power I would not get traction because I can allready peal out very easaly if I want.
Old Feb 25, 2001 | 12:43 AM
SWEETSOUND2001's Avatar
Re: Thats funny because with my car,
so just the y, intake and exhaust will do that for you? how about just the y and intake? i hear exhaust barely makes any gains
Old Feb 25, 2001 | 03:27 AM
BrokenMotor's Avatar
Re: Re: Thats funny because with my car,
i have to disagree, cuz have you seem the stock y-pip?? it has 2 pre-cats, and the y is all jacked up. i gained 10hp at the wheels with just intake a y-pip, here is the dyno graph to prove it. http://www.boostaholic.com/maxima/dyno/index.html . hey man, this is not a civic or someother 1.6L 4banger, this is a V6 3.0L maxima.
Carlos A: for low end power?? you can get some underdrive pully, it is worth it if you have a 5spd, cuz you can do it yourself, as for the auto, hm....get a supercharger and Don's VB mod.
Old Feb 25, 2001 | 07:22 AM
Carlos A's Avatar
Hey guys Thank you for your response.
Hey NightRider,
I am interested on ECU. Please forgive my ignorance, but what is a "S-AFC ir" (is that a company and model of ECU? or a car?)
Old Feb 25, 2001 | 12:14 PM
Super - Air Flow Converter
it is a controller that corrects the fuel curve.
Mar 12, 2020 12:06 AM
Bonka
Sep 14, 2015 11:18 PM
2012Maximus
Sep 10, 2015 12:50 AM
