Splicing O2 sensor wires
i just scraped of a part of my rear o2 sensor. now i see why being dropped sorta sux. can i just buy and 02 sensor and splice the wires to avoid a horrible install?
Actually it's not that bad to complete unplug, unsnap, and rewire the whole thing up. I did it when I removed my y-pipe because I didn't want to splice wires. It will take you 20 extra minutes max once you have the car up.
-Cyrus
-Cyrus
splicing those wires is quite hard , becouse they are stiff like guitar strings !!!!
learned that when i tried to splice mine.
you could get "butt connectors" and try to crimp them nice anf tight and finally use some electric tape around it.
but warning though - did mine that way and it only lasted 3 weeks , finally bought two new O2 sensors and got it fixed the rifgt way
jerry rig is ok for temporary fix , but do it right the first time
Nick
Nick
From under the driver's seat. The carpet has a slice in it to allow to reach the connector. You'll have more room to work comfortably if you remove the drivers' seat: held by 4 bolts : one at each corner.
Jack up your car. Pull out the rubber grommet. Unclip the plastic holder and pull out harness. 4-5" latter there will be a plug. Unplug old and in with the new. Put it back and your done. This takes about 5 Minutes.
