Body Kit - Front Lip - Lowered ( How to get up on stuff example oil change ?)
Old Jan 3, 2004 | 07:23 AM
Ceasars Chariot's Avatar
Old Maxima Legend
I have a 97 Maxima. I have eibach proket springs, and the kyb's. I also have the stillen front lip on the car and with the changes the car is much lower.
After the work was done on the car I had to have some exhaust work done to tighten up and straighten the muffler. This meant I had to drive up on the lifter (LOL dont know what its called) at the Exhaust Pros and have him lift the car up in the car so he could check things out underneath.
The car was too low to make it up on the ramp. So we had to take a 2x4 and cut it in half. Then positioned them so I could ride up on them. Im glad it worked with out them I was getting up.
I have already started thinking about the dealership. They have the same style system i think.
I wanted to hear from other people who are lowered and have body kits. I need to learn the how to's. Are you guys having the oil changed at nissan and are you able to get on the ramp thing ?
what places to go to have things done at ?
Old Jan 3, 2004 | 07:34 AM
Street Reeper's Avatar
Handsome
Put several pieces of wood in your trunk if you take it any where. Make a stair system with them up to the plat form for each wheel and you should be fine.
Old Jan 3, 2004 | 09:44 AM
thebigsadler's Avatar
ahahaha.. eibach's and a lip, you should try JIC's and an m-bumper. I have to drive up on 2 blocks, then jack up the front of the car and jack up the rear to get it high enough to fit the arms under it.
best advice is to just make sure you take your car to somewhere or someone who knows what to do, otherwise you will run into some big issues.
Old Jan 3, 2004 | 11:07 AM
KLoWnPR109's Avatar
Just change your own oil if it's gonna be that big of a deal
Old Jan 3, 2004 | 11:15 AM
MrGone's Avatar
take your car to someone to get work done? whats that like?
Old Jan 3, 2004 | 01:50 PM
araffio's Avatar
I also wonder...
Old Jan 3, 2004 | 01:56 PM
Taken2DaMax's Avatar
Go to a place that has a walk down room under the car. It would of helped ohannon7 but he and I messed up his front lip trying to get his car up the lift. It fu<ked up his paint job. Chips and fractures of the paint all over the place. Sometimes going to a lift can be hazardous for the front. Just find a place that as a walk room under the car, so you can work on it from there.
Old Jan 3, 2004 | 02:31 PM
D-sta's Avatar
Originally Posted by araffio
I also wonder...
Doesn't Jeff do everything for you besides the LED's
-Diego
Old Jan 3, 2004 | 02:37 PM
MAX2000JP's Avatar
My brother has a 4th gen with Stillen kit and H&Rs and my buddy has a lowered C5. What they did was, got a 2X4 and cut a angle on the end of the board. Then, place the board under all the wheels and drive up on the boards. It provides enough clearance to place a floor jack under the car.
Old Jan 3, 2004 | 06:46 PM
Dave B's Avatar
Not DAVEB the parts guy
Nice pink panties, Sally j/k Start wrenching on your own car and you won't have to worry about your body kit. I can't believe you pay to have Nissan do your oil. I can change my oil without even jacking up the car or removing a wheel. I have H&Rs which sit at the same height as the Eibachs and I have a Stillen lip, and I can still get a floor jack under the nose and I've been able to drive onto alignment ramps. I should be getting the rest of my Stillen kit this week so we'll see if there are any problems with the getting under the sides with a floor jack (I thinking it will be fine).
Dave
Old Jan 3, 2004 | 06:48 PM
ny96max's Avatar
i just pop my front lip off... its only two screws and takes less than a minute
...mind you im on Sprints/AGX and still make it on 99% of th lifts out there.
Ant
Old Jan 3, 2004 | 08:04 PM
meccanoble's Avatar
Sports Button FTW
oil change? my car has 2" drop and i just lift car from passenger side with a real jack and i get enough room to get under and do my thing
Old Jan 3, 2004 | 09:05 PM
All*Pro's Avatar
-Diego
[Nelson from The Simpsons] Ha ha
Old Jan 4, 2004 | 09:29 AM
araffio's Avatar
-Diego
Absolutely not.
5-speed conversion and that's it
-Tony
Old Jan 4, 2004 | 02:37 PM
Phatmax98's Avatar
Ceaser...get some airbags..hehe...little expensive..but you won't have to worry ever again
Old Jan 4, 2004 | 07:55 PM
nismos14's Avatar
§è~® f®ÈÄk
drive it up backwards
Old Jan 4, 2004 | 08:01 PM
SXN's Avatar
SXN
the rear vallance is higher.
also do your own damn work on it
Old Jan 4, 2004 | 09:31 PM
RA030726's Avatar
I'm nutty for Nissans
I'd just do the wood thing if you have to drive on a 4 post or alignment lift.
Any one have problems with a clear floor lift or an asymmetric lift clearing side skirts?
Old Jan 4, 2004 | 10:00 PM
dmontzsta's Avatar
Ford Only.
As soon as I get a house with some land on it, I am going to have my contruction friend build me a 3-4 car garage with that under the car walk thing and a lift...hehe...in a dream world that would be nice...
I dont know what I will do when I get my Stillen kit, I am going to keep a close eye on this thread and wait to hear something that will work best for me.
Old Jan 6, 2004 | 12:04 PM
SXN's Avatar
SXN
they make extended length access ramps for a reason
Old Jan 6, 2004 | 01:08 PM
ohannon7's Avatar
Thanks for reminding me
Im just really careful now. I try not to drive up the ramp style lift. I try to use the stalls that have the arms that slide under your car......
BTW-the shop I had paint the lip repaired it for free
Old Jan 6, 2004 | 05:38 PM
SXN's Avatar
SXN
sweet deal, and a nice shop
Old Jan 6, 2004 | 08:46 PM
soulrupture's Avatar
Bro the best thing to do is get a set of ramps for lowered cars at auto barn, pep boys...ect. Keep it in your trunk. Coaust about $25 any gives you clearence to work. For the shops keeping wood in your trunk is the way to go.
Old Jan 7, 2004 | 08:04 AM
haha.. i don't stand a chance on those ramps. A friend of mine bought a set and i couldn't make it 6 inches up the ramp. Worthless.
Old Jan 7, 2004 | 08:20 AM
92 SE-R 02 SE
especially for oil changes!
homeyclaus
Sep 3, 2015 06:15 PM
sonic7
Aug 20, 2015 12:23 PM
maxinout93
Aug 20, 2015 02:17 AM
MikesChevelle
Aug 6, 2015 11:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
