Help! Check Engine Light = 0304, 0807, 0504
According to Haynes Manual
0304 = Knock sensor or circuit fault
0807 = Avap canister purge control valve circuit fault
0504 = A/T control unit or circuit fault
( Auto Transmision ? )
the only symptoms i feel on my car is when it shifts to 3rd at about 3.2 krpm i lose power for a couple of seconds. I've been feeling this symptom for months though, since my battery went dead one day ( left lights on )
only other info:
-i had to drive around without fog lights due to fender bender. ( water damage anywhere in there ? )
-NY weather been acting up...
-my left head light ( low beam ) blew out 3 times in a row in the course of two days.
( i know all these may be unrelated.. but i am just listing all my "car troubles" to see if anyone can relate )
HELP!!!!!!
only other info:
HELP!!!!!!
Mil.light light on
Regards to your Mil.light
A knock sensor will not turn on the light,ever.
Sounds like a o2 sensor problem.Yes an evap valve and the purge control valves and or the wiring are very common.
The wiring at the evap valve and the purge valve use the same power source,so with the ignition key on,check the both plugs for power,check the evap plug first.If the their
is no power,undue the tape rapping to wear the two wires tie off.You will find corotted wires.
Good Luck!!
Good Luck!!
Mil light on
More info that may help
Regarding Mil light,If the engine (cranks,turns over)
but takes a long time to start cold or warm,known
problem,crank angle sensor harness open.Wires rub through
against the power steering pump.The complete harness
(sub.harness)would have to be replaced.Big job,dealer
type job.(Their is a TSB about it)So have your self- diognosis done.
Again Good luck!!!
Again Good luck!!!
ok ok
So... nissan says
Need new knock sensor, new boost sensor and .
your water separator kit is missing, you need a new one
HUH?!
-i know where the knock sensor is. that requires i take off the intake manifold (nissan says one hour at least for that)
-he told me it's common to lose the water separator kit, or.. that in the 96 model.. there was a modification needed on this or recomended on this that my dealer could have done
-as for the boost sensor ?? no clue.
I'll look in haynes manual for these things... they seem simple enough .. but might it be worth labor cost / pain to get it done for me ?
HUH?!
Re: ok ok
Originally posted by amixam69
So... nissan says
HUH?!
So... nissan says
HUH?!
plug up and also turn on the mil. light
Hope this info helps
ENJOY THE RIDE!!!
Re: what does RAD and TSB stand for ?
n/m
n/m
RAD,radiator????Give me more info wanted!!!!
Regards to your shifting and or slight hesitation
since battery died,go to the dealer and have self-learn
cleared.This could be at fault.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
