For us guys without air powertools..............
I'm looking for a decent universal strut nut remover. Has anyone used them for the rear struts and if so, how does it work?
Dave
air tools make it easy, but I haven't found a bolt that I couldn't remove by hand.
most of the time the really tight ones I still have to remove by hand- even with an impact that's supposed to have 600ft-lb of reverse torque.
My stock rear strut nuts were pretty bad but I haven't tried taking my KYB's apart yet. I used an air tool to put them on and the bolt is on there pretty good.
The reason I'm looking into this is because the rear pistons rotate with the bolt unless you hold them with vise grips which is a no no for struts that are going to be reused.
Deezo, grip the flat nub on top of the shock with a med. size adjustable wrench and put a 14mm box on the nut. Lay it on the floor, put your foot on the wrench against the floor so it wount move and break the nut loose. Works for me every time.
WD-40 is your friend, the nut will come right off. The jaws on the adjustable wrench are flat & holds tight. It also doesn't damage that little top nub on the shock like a vice grip does.
Originally Posted by Sin
Many of us (Canadians, snow-belt regions, etc) where there's freakish salt deployment from November to March often have MUCH more rusted bolts and nuts to deal with.
...and we get most of the stuff you guys get in Canada here in MA. My stock struts were bad.
Thanks Tom. At least now I don't have to buy anything extra to do this.
But air tools are a great time saver, man I wish I had some.
I've had air tools for alittle over a year, but I havent started using them until a few weeks ago. I'm just used to not using them. They are faster but like Matt said, there hasn't been a bolt on these cars I haven't been able to get off by hand, but it is nice to use air tools, just makes things easier.
Also a trick for a breaker bar, use your jack handle
MattWithTheMaxima
Jun 30, 2017 01:06 PM
02nissmax
Sep 5, 2015 01:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
