Nissan F.A.S.T. Installation
Old Mar 2, 2004 | 01:54 PM
MaximaVQ97's Avatar
Does Anyone know how to install the 1991-2001 version of nissan FAST i really have no idea!
thanks in advance
-Anthony
Old Mar 2, 2004 | 03:41 PM
bluemaxx's Avatar
Moderator GT-R
thanks in advance
-Anthony
Do you have a copy?
Old Mar 2, 2004 | 04:49 PM
FanaticMadMax's Avatar
Did you happen to buy it off from ebay? If so, then you're in for bad news, they don't work since they are "burned" copy cd's. If they are origninal it will work.
Old Mar 2, 2004 | 05:02 PM
5 spd's Avatar
what is this F.A.S.T.?
Old Mar 2, 2004 | 07:17 PM
PoePoe2797's Avatar
How do you figure...all thats required are the data files. Infact, you dont even need the CD because there is a config file so you can set it to run from your HD. Trust me, I have the whole set with every car in every language. The setup for all cds are somewhat similar. If you got the classic 1 cd F.A.S.T, then it should be in the directory "cddrive://FASTPRG/WIN32/SINKI/SETUP32.exe" Just run and install. If you have different directories, which could be possible but unlikely, you have another cd. In that case, PM me and I'll help
Old Mar 2, 2004 | 08:24 PM
adroga's Avatar
What is fast?
Old Mar 2, 2004 | 10:23 PM
Omegasrk's Avatar
Originally Posted by adroga
What is fast?
FAST is the program that Nissan parts department uses to search for parts for all their cars from 1979 to present. It is fun to use and you could search for your parts on your own computer and just bring in the part number to your local dealer. Unfortunately, each year, there are new models and year changes that are made to the lineup, so FAST gets outdated pretty fast. Installing it onto your system is not all that hard since there is a readme file on the CD. I think the part that might confuse people is when the instruction says to find the NSFASTKY.INI file on the CD and placing it into your C:\WINDOWS\ directory. Try following these instructions MaximaVQ97 that's off of my CD and you might be sucessful. Good luck.
_____________________
How to install Version up of FAST system.
Please install new program the followings.
You can not operate FAST if new system is corrected to install.
<Windows-FAST:32bit>
In case of version up 16bit fast
1)Install 16bit fast Latest version
2)Start FAST system
3)Click 32bit install of HELP menu
4)Appear program SET UP menu
5)When finishing installing ,Reboot the PC
In case of first install 32bitFAST system.
1)Click on SETUP32.exe on the CD (folder FASTPRG\WIN32\SINKI\)
2)Copy NSFASTKY.INI of your CD destination to your PC form the CD
(folder \WINDOWS\)
The minimum hardware requirements for FAST-WIN32
1)The processor is pentium166Hz or more.
2)The RAM is 32MB or more.
3)The color palettes of the screen are 256 colors.
The installing details , please contact your NATIONAL SALES COMPANY.
Old Mar 2, 2004 | 10:54 PM
MaximaVQ97's Avatar
thanks..
thats exactly what i needed to know!!!!
thanks again for all your help!!
-Anthony
Old Mar 2, 2004 | 10:58 PM
Omegasrk's Avatar
thanks..
-Anthony
Finally got it to work I assume.
JRod28
Dec 29, 2023 09:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
