Battery light stays on, during cold morning starts
Old Mar 3, 2004 | 04:44 PM
The_Bomb's Avatar
Lately my battery light has been staying on for a few minutes after I have turned the car on and it only seems to happen on cold mornings. I recently replaced the alternator after my old one died and I also replaced the battery due to it's age. Now whenever I turn the car on in the cold the light stays on but it will go away after I drive for a little bit and raise the RPM's. It is obvious it isn't charging because the lights will dim and then get brighter when the alternator does start charging. There is no sound of a belt slipping I honestly haven't looked to make sure because it is usually very early and I am in a rush to get going and it always seems to eventually work. I need my car to be reliable no matter how cold it is. Is the belt just not tight enough or is the alternator I put in bad already? Please any help would be appreciated.
Adam
Old Mar 3, 2004 | 05:11 PM
Zero Deuce SE's Avatar
Where did you buy the alternator from?
Old Mar 3, 2004 | 05:14 PM
The_Bomb's Avatar
It is a cheap Autolite rebuild from Checker Auto Parts.
Adam
Old Mar 3, 2004 | 05:19 PM
I would highly recommend that you take that sucker back and get an OEM alternator from someplace like NAPA. At the least, you need to have it checked before you get starnded by a dead battery.
Old Mar 3, 2004 | 06:09 PM
The_Bomb's Avatar
So you think it is the alternator?? I can't really take it back... although it does have a warranty that I might try to swap it with another and see if that corrects it.
Adam
Old Mar 4, 2004 | 02:39 AM
I believe that it is an improperly built or reman alternator. That's why you should have the charging system checked.
Old Mar 4, 2004 | 07:57 AM
celica's Avatar
Adam
belt might be loose, seen it happen on my cousin max
Old Mar 4, 2004 | 06:40 PM
young1976's Avatar
He said no loose belt screeches, and I would bring that alternator back or have them test it to make sure it is actually working correctly.
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
