Is there a way to check the level of 5spd manual transmission fluid?
Old Apr 1, 2004 | 10:07 AM
Nealoc187's Avatar
SLOW
I'm drawing a blank here, is there a way to check the level of your 5spd manual tranny fluid?
Old Apr 1, 2004 | 10:22 AM
spirilis's Avatar
On very level ground, get underneath (w/ drain pan to catch any spillage if you'd like) and remove the filler plug... feel inside with your finger, the fluid level should be even with the bottom of the filler hole. If it's below that point, continue adding fluid until it's full.
Old Apr 1, 2004 | 10:23 AM
MardiGrasMax's Avatar
yes. car must be on level ground. unscrew the plug on the front of the trans, a 3/4" rachet will do it. put your finger in the hole, the fluid should be at the same level as the bottom of the hole.
Old Apr 1, 2004 | 03:20 PM
Sin's Avatar
Sin
It is definetly not a 3/4". It is a standard 1/2" square, so any 1/2 drive ratchet should do the trick.
Old Apr 1, 2004 | 06:21 PM
Nealoc187's Avatar
SLOW
Thanks guys. Now I just need to figure out how to get my car off the ground but keep it perfectly level.
Old Apr 1, 2004 | 06:49 PM
Sin's Avatar
Sin
I can easily check the level on my tranny without having to jack it up with the stock suspension.
If you want to be sure it's level, just use an actual level and place it up against the bottom of the tranny along the flat portion.
Old Apr 1, 2004 | 06:59 PM
I30tMikeD's Avatar
good luck with that
Old Apr 2, 2004 | 08:09 AM
tomj's Avatar
Jack up, overfill, lower. Extra fluid will drain out. Jack up, make sure some fluid came out, clean up, put plug back in. If no fluid came out, repeat process until some does.
Old Apr 2, 2004 | 12:05 PM
DAVE Sz's Avatar
Hooooooonda.....
No, jack up, loosen bolt to finger tight, lower, remove bolt, feel inside the hole, fill.
Old Apr 2, 2004 | 12:36 PM
spirilis's Avatar
You may have more luck getting down there from above if you remove the intake resonator, the little white plastic container under the battery, and maybe the battery itself... though I think it's still a little far down there to work from above
Old Apr 2, 2004 | 03:10 PM
RA030726's Avatar
I'm nutty for Nissans
Have you guys ever heard of a lift?
Old Apr 2, 2004 | 03:21 PM
Jason R's Avatar
aka UNCDooD
and i'm sure everyone has at least one in their garage...
Old Apr 3, 2004 | 05:17 AM
VQdriver's Avatar
what do you guys use to fill that sucker up? i remember filling it in my friend's honda after the swap and a few months down the line it turned out to be a bit low...i used a tube and fed it by gravity. is there a better way?
Old Apr 3, 2004 | 05:40 AM
I30tMikeD's Avatar
The way I do it is jack the car up, get under and remove the fill plug. Lower the car back down then use a long funnel with a flexable end and feed it through the top of the engine bay. It's easy if you have the whole stock air tubing removed. Slowly fill until it starts to overflow. Jack the car back up and replace fill plug.
CorollaULEV
30
Aug 9, 2021 08:11 PM
maxinout93
Oct 27, 2015 01:29 PM
ffcbairn
Aug 16, 2015 09:29 PM
