View Poll Results: Where are the dust caps on your max?
On the front wheel hubs
9.09%
On the rear wheel hubs
77.27%
I don't have them
13.64%
Voters: 22. You may not vote on this poll
Dust cap on which hub? Please vote if you know
Old Apr 2, 2004 | 11:02 PM
looslip's Avatar
Horra!!
Is it on your front wheel hubs or the back or do you have none at all?
Here's a pic of what I'm talking about...
I need to know if I remove these things if I'll be screwing something up. I figure if a bunch of you guys don't have the caps anyways, I might as well take it off to make my rims fit.
Old Apr 2, 2004 | 11:32 PM
Taken2DaMax's Avatar
97 max; don't have them on my car.
Old Apr 3, 2004 | 03:13 PM
RA030726's Avatar
I'm nutty for Nissans
the are only on the rear, and i think you need them
Old Apr 3, 2004 | 03:26 PM
DAREN's Avatar
i dont have them on my car. you dont really need them. when you pul them off you will see why. all i did was pack a little silicone in there and put my wheel on.
Old Apr 3, 2004 | 04:24 PM
looslip's Avatar
Horra!!
Thats a good idea!! Did you use silicone glue or what else do you mean?
Old Apr 9, 2004 | 09:52 AM
DAREN's Avatar
anything that will pick the loose dust that may get behind you wheel
Old Apr 10, 2004 | 06:57 AM
Zero Deuce SE's Avatar
The caps are there to prevent dirt and water from getting into the hub bearings. If you take them off, you are running the risk of shortened bearing life from contamination.
Old Apr 10, 2004 | 04:09 PM
Matt93SE's Avatar
STFU n00b!
YOU NEED DUST CAPS ON YOUR REAR HUBS!!!!!
they do NOT use a sealed bearing on the back. Don't believe me? pull the cap off and spin the hub. see the grease and those shiny little metal things rolling around in there? those are bearings. they MUST stay clean. get dirt in them and you can kiss your rear wheel hubs goodbye. they're about $100 each, btw.. not something you want to trash.
Old Apr 10, 2004 | 06:06 PM
looslip's Avatar
Horra!!
Couldn't I seal the rear dust caps with some aquarium silicone glue instead of using those caps?
Old Apr 10, 2004 | 06:32 PM
If you want to invent your own specs you can. It's at your own risk.
Old Apr 11, 2004 | 11:20 AM
global_threat's Avatar
i havn't had rear caps for over four years with no problems. i know what it sounds like when the wheel bearings go out, and i have nothing like that.
off with the caps!
Old Apr 12, 2004 | 05:13 PM
FanaticMadMax's Avatar
those are caps to keep grease sealed in the bearing pack. Ususally FWD cars are found on the rear since the wheels are not propelled driven. RWD cars are found on the front.
Old Apr 12, 2004 | 09:58 PM
looslip's Avatar
Horra!!
So what does it sound or feel like when you have a wheel bearing going out? I do have some slight grinding noises coming from my car prior to taking the caps off. I'm afraid that I might have got some water into there when I was washing the car and I don't have center caps for the rims... I feel like I need to shape the caps a bit and put them back on... Thanks for sharing, guys.
Old Apr 12, 2004 | 10:14 PM
SEmy2K2go's Avatar
Go BUCKS!!!
This cracks me up, take off the dust caps and use silicone? Dust caps, dust...they're on there for a reason to prevent debris from eating away at the bearings. Silicone will not hold up over time. What is the reason behind the need to take them off? If its a matter of wheel fitment, get some spacers, don't remove the dust caps. Your car might look nice with the new wheels, but it won't be driving very nicely in a few months or even weeks if you get crap in there.
Old Apr 12, 2004 | 10:15 PM
SXN's Avatar
SXN
they are built as a removable way to pack in the grease. rebuild and matinence on those bearings is needed...and those caps have a purpose. silicon seems like it would be back for the bearing, not saying it wouldnt keep stuff out, but think how hot breaks get. you know silicon dries out, cracks, wears out. what is keeping it in there with all the heat, water, wear and stress? its a good question bob, but you arent getting good advice....do it RIGHT
Old Apr 12, 2004 | 10:45 PM
looslip's Avatar
Horra!!
okay, I'll be re-fabricating the dust caps this weekend to put back on. I don't think spacers would work b/c the wheels are already at the edge of the wheel well. Thanks again.
Old Apr 13, 2004 | 06:55 AM
Matt93SE's Avatar
STFU n00b!
I've seen on many 4th and 5th gens that you can just tkae a ball peen hammer and tap the ridge off the dust cap and the wheels will fit.
If not, try buying some dustcaps at autozone or whatever parts store. they often fit differently. I I had to remove the dust caps on my car once when I tried to install some MHT wheels... I pulled them off long enough to drive the car home, then I bought some other caps from the parts store that fit under the wheel. total cost.. about $5 and an hour of time.
Old Apr 13, 2004 | 07:46 AM
looslip's Avatar
Horra!!
I'll try that today! Thanks, Matt.
Old Oct 3, 2006 | 04:50 PM
00MaxSE's Avatar
Pointy Elbows
Mine stick to my rear wheels when I take them off. I just use a rubber mallet and gentle knock em out and put them back on the hubs.
Old Oct 3, 2006 | 05:28 PM
irish44j's Avatar
retired moderator
EDIT: Oops, didn't read Matt's post first, so I basically repeated everything he said...
Ok...
There is some terrible advice and logic being thrown about in this thread. This question does not need a poll....it is not a popularity contest. There is one right answer and one wrong answer. Period.
Wrong answer: "you don't need the dustcaps"
Right answer:
The front wheels do not have dust caps on the maxima - the fronts are a SEALED bearing which will not allow any debris to get in. That's why it takes a 3-ton press to get them out.
The rear wheels DO have dust caps, and need to have them because they are not sealed bearings. With no dust cap, the ball-bearings are open to the elements, and all it takes is one little grain of sand getting in there to ruin your bearing. A new hub costs about $100 with bearing. Is it worth $100 to you to take the dust cap off?
Since most people here only believe something if they see a picture of it, here you go:
Here is the rear hub/bearing assembly with dust cap removed. See the shiny silver things? Those are the ball bearings. See how they are open to the elements if there is no dust cap? Yeah....
So, to all of you who know what you're talking about, right on. To the rest of you, stop giving out terrible advice unless you have more to go on than "I took mine off and my bearing is fine."
Old Oct 3, 2006 | 05:32 PM
irish44j's Avatar
retired moderator
also...
That's two bad ideas in one post....wheel bearings get very warm and silicone is not appropriate for several reasons:
1. it is not made to handle heat
2. it does not stick to grease. And there should be grease on the bearing facing.
3. it will not stop debris from getting into the bearing. In fact, depending ont he chemical properties of the silicone you used, it could actually foul the bearing ITSELF!
If silicone was an effective sealant in this application, Nissan surely would have used it in the first place - since a bit of silicone is alot cheaper than a shaped metal dust cap. And we all know Nissan is cheap.
Old Oct 3, 2006 | 05:59 PM
Colossus's Avatar
Quick question in regards to dust caps:
My new wheels don't have center caps, so my front wheels have an ugly rusted part with a cotter pin sticking out. Would a dust cap serve as a makeshift center cap for the front wheels?
Old Mar 22, 2007 | 04:32 AM
Greeny's Avatar
¯\(°_o)/¯
A little rattle can action would work...
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
Andy29
Sep 29, 2015 05:32 AM
