anyone use brake quiet?
Old Apr 17, 2004 | 09:02 PM
1HOTMAX's Avatar
my brakes are driving me crazy..queeks like a **** .i baught brake quit...now where/ how do i apply this lube? man the instructions suck.....it's an orange bottle.
thanks
Old Apr 17, 2004 | 09:42 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
thanks
brake quiet is applied to the back of the pads. "CRC Disc Brake Quiet is specially formulated to dampen the vibrations that cause disc brake noise. It forms a water resistant, high temperature film that will absorb noise and quiet disc braking. Applied to the back of brake pads." -quote from autobarn on the product i believe you picked up. unless you just had the pads replaced recently, you may want to consider just replacing the pads since you will be going just as far to apply the anti squeal. i have had good luck with this stuff
Old Apr 17, 2004 | 10:37 PM
D-sta's Avatar
Just buy a BBK, they don't make noise and they look good behind chrome 20" s
Old Apr 18, 2004 | 02:18 AM
spirilis's Avatar
I use CRC brake grease religiously... laid it on heavy last weekend when I installed Axxis Metal Masters on my rear brakes. I have no squealing/grinding, although the pads do produce a strange "winding down" noise, but that might be partially related to the way the rotors were cut beforehand.
I apply liberal amounts of the stuff to the backing of the brake pads, then let it sit around for a few minutes. I think it cures, similar to silicone sealant. I also apply some to the caliper pad mount sliders at the top and bottom, plus apply some to the caliper itself, on the ring around the piston (or the piston face in the case of the rears) and the backing side of the outboard pads.
Old Apr 18, 2004 | 04:45 AM
1HOTMAX's Avatar
so i have to take the brakes apart to apply this stuff? can't i just apply to the corners/ etc w/o taking the brakes apart?
Old Apr 18, 2004 | 05:50 AM
njmaxseltd's Avatar
I always say if your going to do something, do it correctly, the first time.
Take your brakes apart, clean everything then apply the grease. You'll have much better results.
Old Apr 18, 2004 | 08:02 AM
Conrad283's Avatar
I need a truck
I just had my brakes done and watched him do it. The brake quiet gets applied to "back" (NOT the rotor side) of the brake pad . The pads are pretty easy to remove. Take em out, spray em, and then put em back in.
Old Apr 18, 2004 | 11:56 AM
D-sta's Avatar
Not the Stop Techs I have played with and have dealt with. Maybe it an AP thing.
Old Apr 18, 2004 | 01:20 PM
maxima2001's Avatar
Replacing and/or taking the brakes apart is a piece of "cake". Should take about 45 minutes (including tire removal) to do the work.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
