EGR cleaning service?
Has anyone here ever had this done on their max...I pulled code 03/02 (egr..hi/lo
flow)...it was suggested to me that carbon buildup has blocked EGR passage and has to be cleaned out..Any ideas how much it would cost?
Originally Posted by Ceasars Chariot
any noticable increase in performance ?
I weigh 250lbs and got it off ,just put my chest on the IM and reached behind with a crows foot.
The small tube was 70% blocked i acid dipped it and sandblasted them out. All stumbling went away and hesitations.
my egr is clogged or shall i say PLUGGED but the mechanic told me i would lose HP if i cleaned it out, so i have been trying to figure out what to do ?
I noticed absolutely no difference between a busted EGR and a working one. The only way I knew it wasn't working is because I failed NOx twice.
I was going to clean mine a couple days ago and I took the whole Intake assembly off and tried to disconnect the egr tubes but I could barely see them nevermind get a wrench in there. Did you have to take your intake manifold off to do this? If not how did you get the tube off?
Originally Posted by krismax
For me yes, its not hard to take both of them off.
No the Intake manifold stayed on but I had the intake system off along with the TB and IACV body.
In theory, the egr only works at cruise or light acceleration. When you floor it, it will not have any negative effects.
my03maxima
Jul 28, 2024 07:40 AM
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
