Tire valve seized
Old Apr 22, 2004 | 05:09 PM
Max6spd's Avatar
Tire valve seized
Anyone know how to remove a seized aluminum tire valve cover?
Haven't check the tire pressure for a while because it never looked low or needed more air. I guess it seizing made a good leak proof cover but one that can't be removed.
I tried heating it with a small flame torch but no luck, maybe just didn't do it long enough.
Dealer is saying the only way is to replace the whole valve on all four wheels.
Any help is greatly appreciated.
Old Apr 22, 2004 | 06:21 PM
Mick Max's Avatar
Wild at Hurt
This is worth a try.
Liquid wrench probably with the stem pointed down. Put a few drops on every night. Aluminum does corrode so this could help disolve it.
Short of that you will have to use 2 vice grips. Use a lot of electrical tape or rubber so you dont scar the stem and cap up.
Old Apr 22, 2004 | 07:21 PM
Jepht20's Avatar
Custom User Title...
happened to my step dad's durango...he brought it to a mechanic after he couldn't get them off and it was like $5 or $10 per wheel to replace them. goodluck
Old Apr 22, 2004 | 09:50 PM
Nismo's Avatar
pliers and twisting wont work?
Old Apr 23, 2004 | 04:01 AM
† ErV †
unless when he heated it, he fused the thread...
just give it some effort and have your donut handy in case you have to drive down to get it fixed. it's a cheap fix at any tire place. some even do them for free.
Old Apr 23, 2004 | 02:14 PM
flashover's Avatar
take it to Sam's club. I work there. Tell them you have a flat and you think that it is comming from the valve stem. They will fix it for free. All you need is a membership. Good Luck
Old Apr 23, 2004 | 05:07 PM
Max6spd's Avatar
Thanks for all your suggestions.
I may have to bring it in to a professional if the liquid wrench does not work.
Just hate to think the wheels could get scratched by those power tire removers.
Lesson learned I guess is to use anti-seize grease with those aluminum caps.
BkGreen97
Apr 2, 2016 05:47 AM
bumpypickle
Sep 19, 2015 01:07 AM
Serotta33
Sep 17, 2015 12:14 PM
tardrex
Sep 11, 2015 07:35 PM
