does the drive axel come apart?
Old May 12, 2004 | 03:03 PM
maxspeed96CT's Avatar
The original VQ...
my outer boot is completly shaterd on my right axel , i bought the boot to replace it but im not sure at what part does the axel come apart after it is taken out. Do our axels even come aprt for the ability to change the boot?
help im a ***, i just know how to take stuf aprt and not realy fix it. What do i need to do. or should i just get a new axel?
Old May 12, 2004 | 03:15 PM
Jeff92se's Avatar
I'm needing a caw
You have to pop off the cv joint off. You should be able to use a heavy hammer and gently tap the joint off the axle. Clean up the grease, repack it. Then slide the new boot on the axle. (remember slide the clips on before the boot). Then tap the CV back onto the axle. Slide the boot over the CV and clamp the boot clamps down.
If you are good, you won't even have to remove the axle from the car. I suggest taking the strut assembly completely off to give you more room. That is alot easier than draining the tranny, removing the whole axle etc......
Old May 12, 2004 | 03:18 PM
Synki's Avatar
Make sure the joint is not blown out before you start ripping things apart.
Old May 12, 2004 | 03:58 PM
The original VQ...
ya it has alittle play in it so im kinda worried, but i dont think any dirt got in, i will see when i get it apart.
looked in the hannes manual and there is some kind ring that comes out , is it under the boots? and is it under the outer or the inner boot?
Old May 12, 2004 | 04:54 PM
Zero Deuce SE's Avatar
It does not actually have to get dirt in it to be worn. If all of the grease was slung out during operation, it could cause excessive wear in the outer joint.
Old May 12, 2004 | 05:08 PM
The original VQ...
it got to the point were it made a squeal type noise when i was driving.
is this real bad or just plain bad?
Old May 12, 2004 | 05:17 PM
It's surely bad. I have never repaired a CV axle but they sell reman axles for around $200 if yours is worn enough to warrant replacement. Sounds like it was running pretty dry from what you describe.
Old May 12, 2004 | 06:03 PM
CandiMan's Avatar
Say Candyman 5 times
Even though boot replacement is very possible, for you I would suggest a entire axle replacement since you label yourself as a ***. From what I'm hearing from others I beleive reman axles can be bought at Napa for $60-$70 per axle.
For me nothing but boot replacement for my cars. When caught at a early stage of boot failure, $5-$10 per boot out weighs a lot of things. Plus I get the satisfaction that the job was replace correct, since I did it
Check my homepage for some pics of my last boot replacement, good luck.
MIKE
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Pixel
Sep 15, 2015 05:53 AM
Maxie40
Sep 14, 2015 11:28 AM
