Need help w/ my coilovers!!! **Pics**
Old May 16, 2004 | 07:56 AM
ohannon7's Avatar
Yesterday I went to install my weaponR coilovers and Illuminas. The back coilovers and struts worked w/ eachother but the fronts would not. The circular piece of metal (#1) that the spring sits on and allows you to adjust the ride height would not fit around the strut assembly (#2) . It is basically a little lip that is the same exact circumfrence that is preventing the coilover base from sliding down and being properly seated. Its not the Illuminsa b/c the are the same size as the stock struts and I know other people are running these coilovers so how do I get them on the fronts??? Are the GroundControls the same way?
BTW-this pic is not the exact stuff but you get the idea of what the problem is.
Old May 16, 2004 | 10:17 AM
1FSTMAX's Avatar
I think you need to grind that lip down to get the coilover sleeve to slide down.
Old May 16, 2004 | 10:54 AM
ohannon7's Avatar
really? seems like it would be alot of grinding. If that is the case it seems dumb that they would make the coilovers like that.
Old May 16, 2004 | 12:07 PM
ohannon7's Avatar
there are other people that run these and I have not heard of them having to grinding anything down. only thing Ive heard that people have to grind down is something w/ the AGX adjuster?
Old May 16, 2004 | 02:28 PM
liqidvenom's Avatar
brotherhood of tq
u only grind down when u use kyb's. i think wit those u pop off that round thing wit a hammer slide down the colar and pop it back on.
Old May 16, 2004 | 05:10 PM
white m3 guy's Avatar
you need to take 2 hammers and pop the white cap off
Old May 16, 2004 | 06:15 PM
ohannon7's Avatar
ok cool, so I can just pop it off, slide the piece over it and hammer it back on w/ out ruining the coilovers? Is this normal, or only the weaponR's require this?
Old May 18, 2004 | 04:36 AM
ohannon7's Avatar
By popping that ring off im sure it voids the warranty
anyone else have any input or experience w/ this.
Old May 18, 2004 | 02:27 PM
RA030726's Avatar
I'm nutty for Nissans
Yeop, any modification to the strut voids the warranty. And there is no other way to install them. KYBs get ground down and the tokicos get the hammer.
Old May 18, 2004 | 02:46 PM
ohannon7's Avatar
I havent used the hammer yet, is it pretty straight forward or do I need to do something special?
Old May 19, 2004 | 08:42 AM
liqidvenom's Avatar
brotherhood of tq
nah u just slowly hammer it untill it pops off then install the sleve and hammer it back on... just take ur time doing it.
BkGreen97
Apr 2, 2016 05:47 AM
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
