How to deal with stuck screw?
Old May 24, 2004 | 06:45 PM
wmw's Avatar
wmw
I'm trying to install a CD player on my car. But God damn it the mounting screws of the old radio are really tough. I use the best screwdriver I have but still can't get two of them out. What should I do?
Old May 24, 2004 | 06:59 PM
SupermaxGxe's Avatar
I had the same problem. Put the screwdriver into the screw like your going to take it out and get something solid like a rubber mallet or a pair or pliers would even work. Then give the top of the screwdriver a couple of solid smacks! That sould break it loose enough for you to take the screws out.
-Chris
Old May 24, 2004 | 07:15 PM
5 spd's Avatar
if you have a wrench small enough to fit the shank of the screwdriver, you could use that while pushing against the screwdriver towards the offending screw. or if no wrench is available, use a pair of pliers or your grip to turn WHILE pushing against the screw.
Old May 24, 2004 | 10:08 PM
slickrick's Avatar
drill through those beasts until you can get them out. those small screws are a pita for sure.
Old May 25, 2004 | 01:03 AM
Nismo's Avatar
easiest way if the screw head is stripped is to get a dremel with a cutting wheel and cut a slot on the face of the screw and use a large flat head screwdriver to unscrew it.
Old May 25, 2004 | 01:24 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Aren't audio component mounting screws typically ones something like this that you could use say a 6-8 mm socket on? Granted they may be phillips head, but you get my point.
Old May 25, 2004 | 06:54 AM
Mad-MAX_SE's Avatar
Still kickin'
the ones on the radio are a short, stubby, counter sunk, philip's head screw.
Like 5-spd said use a box end wrench that fits the handle of the screw driver. that should give you enough leverage to break it loose. just push down on the screw driver and then turn the box end wrench...if all else fail, use the dremel tool like nismo said.
Old May 25, 2004 | 07:05 AM
C MAX's Avatar
THAT A BOY WORKS EVERYTIME
Old May 25, 2004 | 09:51 AM
kgb006's Avatar
i had to drill mine out
Old May 25, 2004 | 12:31 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Use vice grips on the shank of the screw driver for your forearm to push as you apply downward force with your hands on the screwdriver.
Worked great~!
Old May 25, 2004 | 09:18 PM
SamMan23's Avatar
gosh. all these violent ways of removing screws. Just use a hand impact. like this http://www.northerntool.com/webapp/w...2&categoryId=0
They're designed to do what you are saying. And useful if you ever have to pull rotors off of a honda.
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
