What are signs of warped rotors?
Old Apr 2, 2001 | 08:21 PM
_DRU_'s Avatar
n/m
Old Apr 2, 2001 | 08:38 PM
HoJo's Avatar
When you press the brake it will vibrate. also the steering wheel might wobble left and right when the break is pressed.
Old Apr 2, 2001 | 08:41 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
you will also feel the brakes pulsing when the brakes are applied...you will feel it first through the pedal and the worse it gets the more the car will shake..
Old Apr 2, 2001 | 08:55 PM
_DRU_'s Avatar
how bout non physical signs?
i dont feel anything different but i will pay extra attention tomorrow. am asking because i hear repetitive squeels that go faster at a faster mph and slower at a slower mph when the brake is applied. it can only be heard under 15 mph though. i thought it my be the pads but the pad's wear indicators would be heard nonstop when the break is applied, right?
Old Apr 2, 2001 | 10:58 PM
MADMAN's Avatar
rear brakes
how would you know about the rear rotors? mines dont shake but it makes a nasty sound when i lighty touch the brakes or in the morning moving off.
Old Apr 3, 2001 | 12:23 AM
Zprime's Avatar
a few things I picked up....
it might not be your pads that are out
it might be your rotor need remachining or it is worn already. and thus the squeal
after hard driving..say auto cross...do not use the e-brake as it will warp your rear rotor....
how do you feel rear rotor is warped...well....I would think it will cause the vibration..i mean your pads are pressing on uneven plates...wouldn't that shake? Pads are not on solid base...they are on calipers..so you might jiggle a little if the rotor uneven..or maybe worse?...
you should check the specs (thickness) of your rotor when you change pads....
Ok...
hope I did not put too much of wrong info...
Old Apr 3, 2001 | 04:03 AM
DNA21's Avatar
Re: rear brakes
If your Max sits overnight the brake rotors will form a thin coat of rust. When you first apply the breaks in the morning (or a rainstorm) you will hear groaning, squealing, and other nasty sounds. Don't worry it is normal for brakes to do this.
Old Apr 3, 2001 | 05:35 AM
Maxwell's Avatar
Re: Re: rear brakes
Originally posted by DNA21
(or father a rainstorm)
I'd PAY to see that!
Old Apr 3, 2001 | 06:21 AM
DNA21's Avatar
Re: Re: Re: rear brakes
Yeah, its alot of work!
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
sdotcarter
Sep 2, 2015 09:53 PM
