look at this fidanza flywheel and tell me if its toast
Old Aug 4, 2004 | 04:09 PM
I30tMikeD's Avatar
The motor is out and the new one is ready to go in, but the looks of the flywheel has me worried. Look at all the hot spots. I have been driving the car for the last week and the clutch has felt fine. But If I am going to replace the plate might as well do it now. **the clutch was fully engaged at 10k rpms**
I think the clutch is fine, but I am posting pics of it anyhow.
Pics are big, but I need them that way...sorry 56k
Old Aug 4, 2004 | 04:15 PM
Jeff92se's Avatar
I'm needing a caw
There are some heat marks. But I've seen those types of marks on my stock steel flywheel also. And I tend not to be harsh on my equipment. You could try emailing Fidanza those pics for their comments. But I believe you might have to have someone check the unit for warpage.
I30tMikeD's Avatar
Old Aug 4, 2004 | 04:17 PM
I30tMikeD's Avatar
Old Aug 4, 2004 | 04:30 PM
Jeff92se's Avatar
I'm needing a caw
Old Aug 4, 2004 | 06:52 PM
Matt93SE's Avatar
STFU n00b!
you can resurface the fidanza friction surface once before replacing it. replacements cost around $100 each.. I'd just resurface is and be done with it. mine looked like that as well after I took it out with about 15k miles on it and a slipping clutch. flywheel is fine. you can do just abotu anything.. resurface, replace, or leave as-is.
Old Aug 4, 2004 | 07:08 PM
Bags's Avatar
VG Ridah's Biatch Hoe
I'd say it's fine, but I also said it was ok to drive on 7/8 bolts holding the flywheel on
Can you take it somewhere to check the balancing?
Old Aug 4, 2004 | 07:28 PM
I30tMikeD's Avatar
Thansk Bags, Matt! I will just clean up the surface a bit and put it back. I did send the pics to fidanza...I will see what they say...if they even respond.
Old Aug 4, 2004 | 08:23 PM
Jason R's Avatar
aka UNCDooD
thats what I'm doing in my '95. what happens if you drive with only 7/8 bolts in the flywheel??
Old Aug 4, 2004 | 08:33 PM
HitManSE's Avatar
Damn man, looks like you've been a bit hard on it If you got a lot of miles on that clutch, might as well replace it and get the flywheel resurfaced while its out. Then you'll have to drive like a grandma for 500miles, but ehh whatever
Old Aug 4, 2004 | 09:27 PM
I30tMikeD's Avatar
clutch and flywheel are about 18k miles old
Old Aug 4, 2004 | 09:40 PM
maximase86's Avatar
I love lamp.
Have that resurfaced and it'll be good as new. I dunno if you ever seen iansw flywheel when he toasted the clutch. It looked the same, but his was also concaved a little because of the ACT PP. But a getting it machined will pretty that up really quick.
S
Old Aug 5, 2004 | 12:36 AM
HitManSE's Avatar
Id still resurface the flywheel, the only issue I see with that is the clutch has already be worn in, the flywheel's surface matches your current disc's wear. If you resurface your going to have a 100% perfect face on the flywheel, but you clutch disc wont be the same. You'd still have to drive like a grandma for 500miles until they are even again. So if its worth it to you to change out the clutch, then do so. Your already changing out the motor & adding headers so I dont think a clutch will hurt too much to toss into the mix
Those 18k were hard miles I presume Its your choice to make man, but personally id just change it since its out anyway
Old Aug 5, 2004 | 02:24 PM
Bags's Avatar
SLIGHT thread jack...
It could cause an unbalanced point on the flywheel. And spinning @ 6000RPM, it's not very safe.
It would be better to use 4 out of 8. Then all 4 points would be equal.
Pm me or start another thread please, so we don't jack this one any more
Old Aug 5, 2004 | 07:37 PM
Nealoc187's Avatar
SLOW
its toast. replace the entire thing. actually replace the entire motor. better yet replace your car with something that isn't a wannabe maxima you poser. kthxbye
Old Aug 5, 2004 | 07:47 PM
BlackCloud's Avatar
As per our conversation Mike, the flywheel is fine. If you really want you can get it re-surfaced for about $60ish. And if you do make sure it's done on a flywheel resurfacer and NOT a brake lathe.
If you choose not to have it resurfaced you should at least refinish it with 3M Scotchbright wheels. Preferably the red ones.
Old Aug 5, 2004 | 08:25 PM
I30tMikeD's Avatar
Well, it's too late to do anyting now. It's back in and we will see how it performs.
AcuraLegend
Oct 17, 2016 08:47 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
jerrod99_se-l
Sep 16, 2015 02:39 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
