Fuel or Trans problem
I have a 2000 Maxima SE Automatic with 52k miles. For the past week, I've noticed driving off after the car has been turned on take off hasn't been as smooth as usual. I put it D and as I give it some gas the car pulsates as if its not getting enough gas. Happens only in first gear. Happens when car is cold. I tried it in low gears and does the same. Checked trans fluid and seems fine. Wasn't sure if it is a fuel (filter or pump) problem or something in the transmission. Has anyone experienced that problem before?
My '02 does something similar, also more noticeable when engine is cold. It seems to happen more often when is hot outside (85+). I don't know what's the root cause though. I cleaned the MAF with CRC's QD Contact Cleaner ($7 at Home Depot) and it seems better, but I cannot tell for sure if this really did the trick, since it has not been that hot outside lately. Yet another 5gen annoyance
BUT, you may want to read this thread... http://forums.maxima.org/showthread.php?t=334762
It is very possible your MAF design is different from the one in my '02, which may not allow you to clean it.
this might be a shot in the dark.. but have you changed your spark plugs? my friend's car did something pretty similar to yours.. and his mechanic told him to change his spark plugs.. ya never know.. it's a cheap fix anyway..
Fuel filter, plugs, PCV, Fuel injection and intake cleaning.
That should smooth things out quite a bit.
bryants95max
Oct 2, 2015 12:52 PM
aminus21
Sep 12, 2015 04:53 PM
