Went to the track yesterday
Old Sep 27, 2000 | 06:10 AM
SteveChicagoSC's Avatar
I ran a 13.87 @ 100.25 mph with a 2.184 60 foot time.
I ran a 14.07 last week. Looks like Lorens fuel pressure mod works!!!
I love all the comments I receive at the track being the only Maxima there. Here are a few samples:
"How did you get this car to go fast?"
"This is an unusual application"
"Your car is badass!!!"
"This car is fast"
"I've got a maxima at home"
"your car is respectable"
"Where did you get the brackets for the SC?"
"I didn't know they made SC's for maximas??"
Old Sep 27, 2000 | 06:11 AM
deathwish's Avatar
You mean you didn't get "What kind of honda is that?"
Old Sep 27, 2000 | 07:21 AM
sx7r's Avatar
What's Loren's fuel pressure mod??
Old Sep 27, 2000 | 08:01 AM
running the secondary fuel pump at all times. n/m
n/m
Old Sep 27, 2000 | 08:29 AM
"Your car is respectable" - ??????!!!!!??????
A 13.87 run at 100+? What an insult.
Old Sep 27, 2000 | 09:08 AM
1MAX2NV's Avatar
Good job steve ->
I think you have the fastest 4th gen auto with SC. I haven't heard any better numbers thant these.
Old Sep 28, 2000 | 04:13 AM
Larry H's Avatar
Nice run...
Wow...getting an fwd auto sedan into the 13's is quite an accomplishment. I'll be thinking of you when I pull my 0-60s in the low 8s.
Just curious Steve, how do you launch your auto SC at the track?
And for chrissake, when are those LSDs from quaiffe coming out?
Old Sep 28, 2000 | 05:38 AM
lanching
I'll stall it up to 2500 and drop the hammer. It hooks decent at 30psi with a burnout prior. It always seems my first run or two at the track goes up in smoke but after that it starts to hook.
Old Sep 28, 2000 | 06:12 AM
sleeper's Avatar
its nice...
to hit 13's ain't it. congratulations. i am happy now! haha
Old Sep 28, 2000 | 06:13 AM
The New CLIMAX's Avatar
Damn nice runs, if you can email me the thing about
the fuel pressure mod, is that with the bigger fuel pump? How is the mod done. Thanks
Old Sep 28, 2000 | 01:07 PM
Kato
Can I get a ride? =)
Nice run, Steve. That's definitely the fastest auto s/c time I've heard of yet. Think we can meet up next time I'm home from school?
Old Sep 28, 2000 | 02:13 PM
jgadlage's Avatar
Are these the directions? (found it in my old email)
I have noticed over the last year I would get occasionally a drop in base fuel pressure after letting off boost. A quick tap of the throttle would bring it back up. I have noticed that from time to time I would get some fuel leaking from the hard line fitting that the
feed hose for the auxiliary fuel pump goes to. I have tightened the clamps and replaced the hose, but it would still come back.
I finally found out why. The auxiliary fuel pump runs off a Hobbs switch that allows it to only run under boost. When you let off and go out of boost, the fuel pump immediately stops and blocks some of the fuel flow dropping the pressure. This stoppage creates backpressure in the line and caused the fitting to leak due to the pressure. If the backpressure was great enough, it could actually damage the in-tank pump.
I originally thought about pulling the in-line pump and replacing it with a higher flow in-tank pump. I was suggested to just run the auxiliary pump all the time. I talked to Vortech and they said the T-Rex pump was designed for 100% duty cycle. So, I tried it. The fuel pressure stays very consistent and does not run rich under non-boost conditions.
I strongly recommend that all SC owners do the same. If you feel any jerkiness going into and out of boost, it may be related to the same problem. To run the pump all the time when the engine is running, just unplug the vacuum line going to it and cap it off. There are no ill effects since it only provides additional load for the fuel that is already there.
Location = a little bit behind the battery.
It’s not that blue cylinder thing with the tube coming out the top. Its smaller than that. Probably just in front of that device.
Which tube --> look where the vacuum line goes into the little thing in from the throttle body. In the stock setup, just a tube connects there. With the supercharger installed that tube has been slip with a T connector. The extension that needs to be pulled comes from the T connector and connects to a switch(that switches on...activates off based above a vacuum). Just pull this one tube off the side of the switch.
I just pulled the tube off, folded the end over, and wrapped a piece duct tape around it. You know you did it right if you put your key in the on position, you can hear the extra fuel pump(on don't have to actually start the car).
Yes I did do the mod for the hobb switch. Does it really do anything I honestly doubt it, b/c I really don't feel the car is anymore responsive. It just makes the fuel pump stay on all the time instead of it turning on and off. It’s more efficient for it to stay on though. Lemme think the hobb switch is the gold/brownish piece on the driver side where the auxillery fuel pump is. There is one hose that runs to the hobb switch and that is the hose you plug up. Just take that hose off and plug it up wa-la your finished.
[Edited by jgadlage on 09-28-2000 at 04:23 PM]
Old Sep 28, 2000 | 05:37 PM
BIGMAX's Avatar
Does this work on a non s/c 4th gen, and if it does does anybody have any better instruction. I can't locate any of that crap in my engine.
Old Sep 28, 2000 | 05:39 PM
Lyt97SC
hehe ...no
its a SC only mod
Old Sep 28, 2000 | 05:44 PM
Remington's Avatar
No Bigmax
You have no blower so all of the above doesn't apply to you. The s/c kit has a second fuel pump to supplement the primary one. This is only needed because of the increased fuel requirements under boost, hence you don't have this.
Old Sep 28, 2000 | 06:15 PM
BEJAY1's Avatar
Conecarver
Outstanding run! Can't wait til we meet up at a local track sometime. Just you wait you and your S/C. Wait til I get my Y-pipe and ECU. Just you wait - until I ask real nice..."Could I get ride?"
Old Oct 1, 2000 | 05:47 PM
NeO OnE 2
CONGRADS
WoW , you are the first 13 sec auto Max that I know. Were you running on slicks or street tires?
Old Oct 1, 2000 | 05:51 PM
Maximamike's Avatar
Re: CONGRADS
Don's auto Max runs high 12s. Nice run, Steve
Old Oct 2, 2000 | 05:44 AM
Re: CONGRADS
I was running the stock tread.
Old Oct 2, 2000 | 06:19 AM
Nismo87SE's Avatar
Re: CONGRADS
Actually Don in Texas runs low 13's in his auto. But that was with NOS, slicks and an I30 tranny. His car is wicked fast on the NOS and quick enough to beat a modded 5spd off the NOS.
Old Oct 14, 2001 | 10:36 PM
Nismo87SE's Avatar
Re: Are these the directions? (found it in my old email)
This has to be added to a FAQ somewhere. I bet alot of the new S/C owners didn't know about this old school trick.
Originally posted by jgadlage
Old Oct 14, 2001 | 11:06 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Nice times!!!
Never hooked up the Hobbs switch from the beginning, so I don't really know how it feels.
Old Oct 14, 2001 | 11:49 PM
AznWontonboy's Avatar
Re: Re: Are these the directions? (found it in my old email)
check your pm's
Old Oct 15, 2001 | 08:53 AM
Synki's Avatar
Congrats Steve, but this i know this isnt your first trip ito the 13's. (Gotta love newbies)
Maybe some of you guys should look @ his sig. He has been 13's and will stay there.
Don is NOSed and runs 12's, not 13's. He runs 14.2's (or so) off the bottle.
I believe the fuel mod is for the boosted guys only, not use NOSed or N/A guys.
BTW-i30krab is 13 second auto himself. He was a NE guy but now living in NV.
Old Oct 15, 2001 | 08:56 AM
Cumalot's Avatar
Hm...I have to look into this.
Old Oct 15, 2001 | 09:15 AM
Frezny's Avatar
12.2 WITH early shift problems on bottle
14.1 NA
nothing agaist you Sinki... just trying to clear things up for the other guys.
But this is becoming academic...
Old Oct 15, 2001 | 09:17 AM
Sprint's Avatar
Drew's AUTO ran 13's.. and David L's had the potential to do 13's
Old Oct 15, 2001 | 09:19 AM
Cumalot's Avatar
What about me?
Old Oct 15, 2001 | 09:25 AM
Sprint's Avatar
Originally posted by Cumalot
What about me?
who in the blue hell .. are you?
Old Oct 15, 2001 | 09:37 AM
Synki's Avatar
14.1 NA
I know, its all good. It should be cleared up though b/c everyone does seen to have dif #.
Cant forget me...i am an auto 13's.
Old Oct 15, 2001 | 09:44 AM
Cumalot's Avatar
[QUOTE]Originally posted by SprintMax
QUOTE]
Do you like...PIE?
Old Oct 15, 2001 | 10:08 AM
Sprint's Avatar
slip?
Old Oct 15, 2001 | 10:15 AM
Synki's Avatar
slip?
Awwww wait... hold on..lemme pull it outta my pocket There is it.
What's the matter? Having trouble seein me run 13's?
Old Oct 15, 2001 | 10:16 AM
Sprint's Avatar
not on a 50 shot
Old Oct 15, 2001 | 10:37 AM
emax02's Avatar
This post is from over a year ago and your calling them newbies! . BTW did Crab actualy run his car or are you just making a educated guess?
Old Oct 15, 2001 | 10:46 AM
Synki's Avatar
[QUOTE]Originally posted by emax95
[/auote]
Lazy eye huh?
No, i didnt know this post was from a year ago. I thought it was a recent post considering i havent seen this post anytime soon so it makes sense.
Are you being a smart a$$ Ethan? o_O
According to a few other who knew him really well & what i was told, yes he is 13's. Have i seen it no.
ANd who said i was running 50 shot?
Old Oct 15, 2001 | 10:58 AM
Synki's Avatar
Im sorry, I am the Newbie myself.
Old Oct 15, 2001 | 11:04 AM
voltman's Avatar
What?
Old Oct 15, 2001 | 11:09 AM
Sprint's Avatar
Originally posted by voltman
What?
do you like pie stond cold?
Old Oct 15, 2001 | 12:52 PM
emax02's Avatar
No, I just got a little kick out of it. BTW All in good nature my friend. .
Sprint & Voltman, you guys are funny as hell!
