what size tire should I get on 16*8?
Old Apr 13, 2001 | 01:14 AM
maxspeed79's Avatar
just picked up some new rims today, what size tire should i use? thanks..
Old Apr 13, 2001 | 06:53 AM
Keven97SE
225-50-16 or 225-55-16 would fit *perfectly*. I'd pick 225-50-16 for the shorter sidewall over 55's...and they're only slightly smaller than the stock tires overall. Your speedometer will read 88 mph at 85 mph, something along those lines (minor).
Old Apr 13, 2001 | 10:45 AM
NYCe MaXiMa's Avatar
hmm
I think you should go wider, 235-50-16...... A lot of people here throw 225 series on the stock 97-99 16 x 6.5 rim! It's a bit wider... just like people fit 235 tires on 17" by 7-8 rims, you can put 235s on your 16 by 8... The only problem is, I don't know how easy it is to find 235/50/16 tires... check tirerack.com
Old Apr 13, 2001 | 11:36 AM
Chunger's Avatar
My other car is a Hybrid
Depending on your offset...
How about the easy to find 245/45 size? 235 is a hard size to find, IIRC..
245s will stick out a little... 225s will be flush with the rim... be careful parallel parking!
Old Apr 13, 2001 | 02:38 PM
LoveSick's Avatar
don't go for too wide, you will find yourself loosing straight line performance. I would say go with the 215 50 or the 225/45.
make sure you get the PROPER offset or you will loose cornering stability.
Old Apr 13, 2001 | 06:54 PM
maxspeed79's Avatar
I just bought Kumho 225-50-16 VR.. It's kinda sticking out, but I guess I'll get used to it.. Thanks for all your comments,
But after putting rims on, drove few miles and every time I trying to stop or slow down, my handle turning in to right side by little. any comments would help.. thanks..
Old Apr 13, 2001 | 08:52 PM
Chunger's Avatar
It typically takes a few miles (100?) before the tires "get in the groove" and track well... I can't explain it... but it happens to me every time...
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
