How to make my headlights (all of the front lights) brighter?
Old Oct 20, 2004 | 08:18 PM
maximka's Avatar
how can i get rid of the "yellow" light look? i am thinking of getting something brighter and clearer... and to spend as less money as possible
do i just change the bulbs? some of those bulbs are like 75$ PIAA something...
what can i do?
Sergei
Old Oct 20, 2004 | 08:30 PM
Loe max's Avatar
To answer your first question... The lights won't be brighter unless you run more voltage or buy high powered bulds. If you get colored bulbs with the same wattage, they are dimmer per say, but have a higher temperature so they appear brighter. The only high powered bulbs I'd recommend is a 9007 conversion bulb. Look under 4th gen FAQ. I did this on my 3rd gen and couldnt' be happier.
To answer your second question... change your light bulbs
Old Oct 20, 2004 | 08:55 PM
maximka's Avatar
I appreciate your response!
how do i run more voltage? how much would it cost? and the 9007 bulbs, do i need anything else in order to replace those?
I am a total noob when it comes to electrical stuff...
I will also look under the 4th gen FAQ
any more ideas??
Old Oct 20, 2004 | 09:00 PM
Loe max's Avatar
4th gen FAQ's how-to's ect... will give you steps and what you will need. It has the answer to all of your questions about lighting
Old Oct 20, 2004 | 09:07 PM
matt90max's Avatar
higher power bulbs work good if you directly connect it to the battery with new relays, bigger wire and new high temp. bulb connections. anything higher then about 75-80 watts low beam will probably burn out factory wiring harnesses. Silver stars are about $40 and are not yellow, somewhat white 4200k color temp. high watt 90-100 xenon filled fake hid is about 5200k and hid conversion is less power 30-40 watt but can be 6000k-15000k $300+
Old Oct 20, 2004 | 11:25 PM
SPiG's Avatar
SomePsychoGuy
Convert to 9007. If you drive at night you will love that mod forever. It is one of the best small mods a 4th gen can do.
Old Oct 23, 2004 | 08:53 AM
RA030726's Avatar
I'm nutty for Nissans
dont do the 9007 conversion... that guy who did it was a nutt case!!!!!!
Old Oct 23, 2004 | 09:20 AM
ChromeSE5's Avatar
is this better than h4's like in the 5th gen?
Old Oct 23, 2004 | 10:26 AM
Loe max's Avatar
H4's have a superior beam pattern, mainly because the 5th gen reflectors are designed for them.
JSutter, have you done the 9007 conversion to recommend not doing it?
Old Oct 23, 2004 | 10:30 AM
RA030726's Avatar
im am the one who wrote the write up. i was just screwing around, since i had my name changed hehehe I love my 9007's
H4 is much better than 9007 so 5th gens are fine with their stock bulbs. If you want more light just change the harness.
Old Oct 23, 2004 | 10:35 AM
Loe max's Avatar
ya, I didn't catch that until I went back to your thread
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Samedi
Aug 12, 2015 01:54 AM
papo99
Aug 9, 2015 07:32 AM
kirkhilles
Aug 8, 2015 10:53 AM
