cheap pads = spongy brake pedal???
hey guys, just had a couple of quick questions about whether or not crappy brake pads would cause a spongy brake pedal? i just bled my brakes hoping to remedy the problem but it only seems to have gotten a little better. i also installed new brembo blanks. the pads i have on the max right now are whatever pads Just Brakes uses (i'm sure it's the cheapest pads they can find). so i was wondering if switching to Ceramic brake pads (raybestos qs, or bendix ceramics, etc.) would possibly remedy the spongy feel. any info would be great. thanks in advance!
You're still using pads? Switch to Tampax!
Spongy brake pedal feel is caused by air in the lines or weak-@ss brake lines ballooning. As long as the pads are the correct thickness and aren't made of cotton, they shouldn't have anything to do with a spongy feel.
Did you install the pads? If so, check to make sure you aren't leaking brake fluid anywhere and possibly bleed all four lines again. Even if you didn't work on all four lines, I've had to bleed all four to get it right.
Question Brian,
When you put constant pressure on your brake pedal, does it slowly sink all the way to the floor? If so then it is either a leak in the system, or the brake master cylinder is going out and needs replacement.
If not, keep bleeding the brakes at all 4 corners, brake pads never cause spongy feel. Brake pads aren't squishy, not even a little bit. Sometimes you need at least 5 bleed attempts at each corner while constantly filling the brake fluid.
You have two things working against you
1) You could have improperly bleed the brakes
2) You could have improperly bed the brakes. New pads will feel like crap until they have a chance to break in a bit
Ammi : What was the order on bleeding all lines?
drewn- how's it going... i don't think i have a leak in the system or else i'd be losing fluid right? but even after i've stopped with the first couple of inches of brake pedal travel i can continue on and push the pedal all the way to the floor. i was guessing air in the lines?
jeff92se-i'm going with your option 1...
cutlr7- yeah, i'm gonna rebleed them, and also, how do you bleed the Master Cylinder? thanks for all the help guys...
Originally Posted by dallas0593
It is recommended to start with the right rear wheel, then proceed to the left front, left rear and then right front wheels, in that order
1. Right Rear
2. Left Rear
3. Right Front
4. Left Front
that's the way i did it... maybe that's what's causing the spongy pedal.
Originally Posted by Terran
How is that done?
crack the lines at the MC and slowly pump pedal till fluid flows out of the MC, do this slowly... Made a difference and requires 2 people....
Pump, Pump, release valve.
since we are on the discussion on brakes if you have xdrill/slotted rotors... which way is the pattern suppose to go?? pics would help
wouldnt you be bleeding the master cylinder when you bleed the lines.... kinda unnessary isnt it?
The easy way to test it, is hold the pedal to the floor, and see if the pedal becomes softer. If so, brake fluid is slipping by the master cylinder pistons and should be replaced.
Otherwise, just bleed the heck out of it and see if it helps first.
))) <= If those were some of the vanes, and they were spinning clockwise, they would throw air to the outside = GOOD
((( <= If those were spinning clockwise, they would scoop air in = BAD
Get it?
driver side firewall, u cant miss it all the brake lines goes to itdo your self a favor and buy a flare nut wrench 10mm before you do it i didnt and had and stripped the nut on the brake line, if you do too no biggy get a line cutter, new line (standard size) and double flaring tool, and redo the line gl
So just like bleeding brakes? Could you give me some idea where the master cylinder is located?
^^^ hehe... just rebled my brakes and installed some Satisfied Ceramic Pro's. haven't been driving them long enough to see if they are better. the brake feel is much better now after rebleeding them. thanks for all the input guys.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
