We finally got a CNC Machine! Any Requests?
Old Nov 9, 2004 | 11:33 PM
SSR Engineering's Avatar
To celebrate the new CNC machine we want to help out the community by taking some requests! If there are anything you guys want we can pretty much make the following (if not more)
- Brackets, flanges and adapters (BOV, Filter, MAF)
- Engine Dampeners
- Rocker Arm Stoppers
- Shift Linkages and Short Shifters
- Fuel Rails
- Fuel Doors
- Oil Pan spacers
- Suspension parts (lower tie bars etc)
- Oil cap, Radiator Caps
- Endlinks
- Shift *****
- Coil Pack Covers
And many more, so if any of you guys have any requests lets hear it, and we'll be happy to make you guys something.
Old Nov 10, 2004 | 12:09 AM
krismax's Avatar
Father of the 00 VI
- Engine Dampeners
- Fuel Rails
- Fuel Doors
- Oil Pan spacers
- Endlinks
- Shift *****
- Coil Pack Covers
I know i will after winter need custum brake brackets but not now many things i need to finish first.
Old Nov 10, 2004 | 12:13 AM
tedo007's Avatar
faster than you think
make some RSB
Old Nov 10, 2004 | 12:21 AM
95maxrider's Avatar
Lightly modded
Exactly what are engine dampeners?
I would be very interested in you designing an improved shifter linkage for the 5 speed Maximas, but I have no idea if that is even feasible....what about radial arms?
Old Nov 10, 2004 | 02:33 AM
nubiannupe's Avatar
OG Maxima.org Member
- Engine Dampeners
- Fuel Rails
- Fuel Doors
- Oil Pan spacers
- Endlinks
- Shift *****
- Coil Pack Covers
I have a rather unusual request...
If you look at the image above, you'll see where I have circled, the top of the shock tower. There's a black 'dust cover' of sorts that covers the nut at the top of the strut. Would it be possible to machine something like that, except in something with a bit more 'sheen' to it? If needed, I can mail you one of mine to use as a template.
Old Nov 10, 2004 | 05:04 AM
MrGone's Avatar
I'd be down, depending on cost ofcourse.
Also how about not producing anything BlehmCo or Jeff already make
Old Nov 10, 2004 | 05:11 AM
Zack342's Avatar
how about an adapert that will allow the 2000-2001 Variable Intake Manifold to be bolted on to the 95-99 engines
Old Nov 10, 2004 | 05:14 AM
euromaxima's Avatar
I am having one of those machined now by a friend. but he is making it so I can raise the nut so it makes my front go about 1-2 inches lower.
Old Nov 10, 2004 | 05:36 AM
cardana24's Avatar
Blown
can you make a custom emblem? If so please let me know...I am very interested in having a custom emblem made.
Old Nov 10, 2004 | 06:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
IMO that's going to be a PITA to make.
they are going to need to machine a groove in the piece of billet alum to fit a O-ring. the o-ring will act like the retainer and seal...just like what the stock rubber piece is doing.
too small and it'll flop around/out...too big and it won't fit.
Old Nov 10, 2004 | 07:19 AM
Zack342's Avatar
SSR remember this ......http://forums.maxima.org/showthread....e+honing+gains
Old Nov 10, 2004 | 07:24 AM
dmontzsta's Avatar
Ford Only.
How about a full on battery holder, I have seen them in boats, but never in a car. It would go under the baterry and on top with two holders on the sides, I will see if I can get pics.
Old Nov 10, 2004 | 07:29 AM
Zack342's Avatar
you mean like this ?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33575
Old Nov 10, 2004 | 08:23 AM
chris'smax's Avatar
I would really like to see a larger flow fuel rail for the 5th generation!!!!!!
Old Nov 10, 2004 | 08:38 AM
Larrio's Avatar
The Definitive AE Master
shorter endlinks so the front sway bar has more lateral movement
Old Nov 10, 2004 | 09:16 AM
dmontzsta's Avatar
Ford Only.
Originally Posted by zack342
Yes, very close...just without the stupid design up on top.
Old Nov 10, 2004 | 09:54 AM
deezo's Avatar
Wheel spacers maybe?
Old Nov 10, 2004 | 10:29 AM
Jeff92se's Avatar
I'm needing a caw
Why do they need to make them if these already exist?
JeffesonM's Avatar
living out of a maxima...
how about adaptors to use the PF throttle body?
Old Nov 10, 2004 | 10:49 AM
chris'smax's Avatar
i second that
Old Nov 10, 2004 | 11:00 AM
Zack342's Avatar
this is a really good one. also if you guys could do an intake manifold or adapter for the 00-01 manifold that would be cool.
Old Nov 10, 2004 | 11:03 AM
chenzarino's Avatar
A set of shortened dogbones for my motorsickle
Old Nov 10, 2004 | 11:10 AM
waveridr85's Avatar
adapter for the egr for the 00 vi for our 4th gens and a pathfinder throttle body adapter plate for the 00vi and the mevi
Old Nov 10, 2004 | 11:14 AM
tomj's Avatar
SC bracket so I can make my own kit for half the price of Stillen's.?
Old Nov 10, 2004 | 11:18 AM
vsamoylov
a short throw shifter for a 2k2-2k3 max would be nice.
Old Nov 10, 2004 | 11:23 AM
Glude's Avatar
make us 2k4 maximas something good, we dont have enough mods.
Old Nov 10, 2004 | 12:03 PM
JdoubleOe703's Avatar
teddibear703
your mailbox is full... i want to send u a pm or email... thanks!
Old Nov 10, 2004 | 12:15 PM
BEJAY1's Avatar
Conecarver
Yes, more flexibility to install the 00 VI.
Old Nov 10, 2004 | 12:23 PM
Jason R's Avatar
aka UNCDooD
my pathfinder throttlebody can bolt right on to my USIM. adapter plates =
or you could produce a bigger billet throttlebody that is a direct bolt onto the USIM, MEVI, or '00 VI.
Old Nov 10, 2004 | 12:45 PM
Mizeree_X's Avatar
Getting back to his roots
That sounds like $$$$ for the small gains it provides.
How about longer wheel studs? Not sure if a CNC machine is the right tool for the job, but I thought I'd throw it out there.
Old Nov 10, 2004 | 01:04 PM
Bman's Avatar
I really don't know if this is already manufactured or if they're even an improvement over bolt adjusters, but what about:
Camber Plates
Seems like a CNC type part to me...
Old Nov 10, 2004 | 01:30 PM
Dasyce's Avatar
Wheel Spacers!!! 20mm with bolts!
Old Nov 10, 2004 | 01:39 PM
Larrio's Avatar
H&R 5mm and 10mm spacers have been out of stock for the past 5 months. Now would be a good time to get some spacers out for 240sx/maximas/350z's
Old Nov 10, 2004 | 02:16 PM
Shadow's Avatar
Um yeah, that's not going to happen. Considering Vortech blowers are like $1500 for just the blower unit, by the time you get the fuel and piping together along with all the miscellaneous parts, your way up there. But hey, if you can do it for $1800, more power to you...
I have my doubts that SSR is going to waste their time designing random things. CAD designing isn't easy, nor is it cheap. And even if they did design it, would you buy it? Anyone have an idea of how much a one off part or a small run of parts would cost? CNC mills are great for stuff like throttle bodies, or anything that requires 3D capabilities. For flat brackets and stuff, there are cheaper ways.
Old Nov 10, 2004 | 02:36 PM
Triple8Sol's Avatar
I miss the .org!
Short Shifter For The 02-03 6 Speed Mt
Old Nov 10, 2004 | 02:49 PM
stephenlc's Avatar
they sell V1 and V2 blowers on e-bay all the time for $300-$100 all the time. A bracket would be a good idea but going to to be very hard to make.
Oil pan spacer sounds nice. That way when its time to turbo, I don't have to worry as much.
Old Nov 10, 2004 | 02:50 PM
HNDA ETR's Avatar
Still Here... IM me for more..
how about that turbo kit for a 5.5 gen maxima? or a short throw shifter...
Old Nov 10, 2004 | 03:36 PM
Terran's Avatar
I was going to suggest both of those...excellent idea's.
That's even better than the PF TB (should've kept reading before I posted ).
I think they could do pretty well with an adapter for the '00 VI...If it was bolt on it would pretty much replace the MEVI for 4th gen VI's.
Old Nov 10, 2004 | 03:38 PM
MrGone's Avatar
Camber Plates
this has been made, I'll forward the thread to the guy(s) who designed them
Old Nov 10, 2004 | 03:46 PM
Wisky97SE's Avatar
Wheel spacers with studs. For a fair price.
