removing tints......
Old Nov 11, 2004 | 11:22 PM
panda_1's Avatar
anyone know how to do it, with using tools and chemicals from the house? also to do it without killing the rear defroster.
Old Nov 12, 2004 | 06:41 AM
Punjab_Max's Avatar
I'm not too sure about the defroster, but I had to remove my front tints cause they failed me at inspection for them. Anyhow I just took a razor, lowered the window, and just tried to lift the tint off of the window from the top corner. Once I had a little piece I could grap on to, it just peeled right off...Really easy, took like 5 min, if that.
Old Nov 12, 2004 | 07:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
spray ammonia on the tint. (use plastic to protect the other areas)
stick a black garbage bag over it to contain the ammonia.
roll car to the hot sun....bake for 30-40 min (making sure ammonia does not dry).
pull off tint by lifting a corner and SLOWLY peeling it back...spray more ammonia if you have to keep it wet.
clean up the rest of the stuck glue w/ windex and a WHITE plastic/teflon scrubbie pad.
then get some febreeze for the car because it's going to stink for a day or so.
Old Nov 12, 2004 | 08:24 AM
minsbang's Avatar
I used Windex, a razor blade, and paper towels. It worked fine.
Old Nov 12, 2004 | 12:36 PM
SPiG's Avatar
SomePsychoGuy
http://www.tintdude.com/remove.html
I found this AFTER I had ruined a few of my lines in the rear defroster and removed most of the tint. The front ones aren't bad and if you follow these instructions the back shouldn't be too hard either.
Old Nov 12, 2004 | 12:50 PM
panda_1's Avatar
thanx alot guys ima have to do this, wanna ride tint less for a while and then get them re-done.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
