What are the diffs between H4 VS 9004???
Old Nov 14, 2004 | 06:11 PM
Fearfox's Avatar
Looking at both bulbs i been only so far seen H4 uses more wattage but both bubls create same amount light intensity. Also why is it that sylvanias H4 says for motorcycle only????
Old Nov 14, 2004 | 06:27 PM
Loe max's Avatar
the bases for H4's are different. not only that, the filament placement for H4's are vertical, while 9004's are horizontal. H4's are a different design and are used in the 2000-2001 Maxima's in USDM cars IIRC.
Old Nov 14, 2004 | 07:57 PM
white m3 guy's Avatar
h4's give better light displacement
Old Nov 15, 2004 | 10:23 AM
SPiG's Avatar
SomePsychoGuy
The Cefiro housings also use H4s IIRC. I am not sure but I think the H4 is better than even 9007 but could easily be wrong. I know 9007 destroys 9004.
Old Nov 15, 2004 | 11:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
literally...night and day.
9004 is just 2 pancakes on the wall.
H4 has a nice cutoff pattern.
Old Nov 15, 2004 | 11:26 AM
Loe max's Avatar
the cutoffs are very sharp, as good as you'll get before going with projectors
Old Nov 15, 2004 | 11:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
yes that's why i tell people not to put HIDs in their 9004.
H4 fares a little better.
Old Nov 15, 2004 | 08:49 PM
MrDicks95SE's Avatar
Offset Is Everything.
does anyone have pics discerning 9004 from H4? that would be nice.
Old Nov 16, 2004 | 05:14 AM
Bill Brasky's Avatar
Seperated at Birth?
i'm interested in this H4 bees knees...
Wouldn't the different filament arrangement screw up the light projection (reflection) resulting in the blinding of so many innocent drivers?
Old Nov 16, 2004 | 05:57 AM
Loe max's Avatar
Yes, plus the base of 9004 and H4 bulbs are totally different, you'd have to do custom work to make them fit properly in the headlamps.
Old Nov 17, 2004 | 02:45 PM
locklear's Avatar
I think the wiring connectors are different too between the 2
Old Nov 17, 2004 | 02:59 PM
RA030726's Avatar
I'm nutty for Nissans
the two are compleatly different. H4 is all metal, even has a shield in it for a nice cut off. 9004 are just plain old skool junk. You guys are getting me thinking........9004 to 9007 was good......how about 9004 to H4? that would take some work.........and I just may try it out.
Old Nov 17, 2004 | 05:51 PM
Loe max's Avatar
I'm thinking since your a 4th gen you can probably somehow do a cefiero/4th gen hybrid since cefiero's use H4 bulbs according to the person who posted above
Old Nov 17, 2004 | 07:42 PM
RA030726's Avatar
the thing is the bulb has to be in the correct spot inside the light to get a good pattern. And our lenses suck butt anyway. I have an extra 96 light to screw with....similar to the 3rd gen light. I guess there is only one way to find out huh?!
Old Nov 17, 2004 | 09:30 PM
just go buy cefiro headlights if you want H4s. its made for H4 bulbs anyways.
Old Nov 18, 2004 | 06:01 AM
Loe max's Avatar
<--9004
<--H4
Old Nov 18, 2004 | 06:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you're going to do all that work with 9004 to H4 might as well get a bixenon projector in there and call it the day.
Old Nov 18, 2004 | 01:28 PM
RA030726's Avatar
Mr****s95SE because I think they look like **** on a maxima. I really hate the blacked out ones. They fit crappy, and just dont do it for me. Yes the beam patter is better but thats it. I cant justify splending that much money on a cosmetic only mod that fits horrible. If I had an I30 then I would do it.
DanNY youre right. thats the reason why I have not even considered the idea of H4. Projectors would be the way to go no matter what. But I may just get a $5 bulb and mess around.
Old Nov 18, 2004 | 06:05 PM
Loe max's Avatar
Old Nov 18, 2004 | 06:12 PM
yeah the fitment of cefiros are pretty crappy but im happy. as for the 9004 to h4 conversion, if youre gonna do it, good luck. looks like a lotta work.
Nismo87SE
Mar 2, 2001 05:06 AM
Naughty
Feb 2, 2001 03:43 PM
tclee
Nov 27, 2000 10:59 PM
