Is a test pipe worthwhile...
Old Nov 20, 2004 | 08:57 AM
JChan's Avatar
I will be purchasing a WarpSpeed Y-Pipe in the near future and would like to know if it would be worth the extra money to swap out the cat. converter with a test pipe while I am down there.
Old Nov 20, 2004 | 09:08 AM
meccanoble's Avatar
Sports Button FTW
nope, unless u r FI. u wont see much gains and the little gains u see arent worth hurting the environment.
Old Nov 20, 2004 | 09:42 AM
JChan's Avatar
What horsepower and torque numbers would I be gaining if any say I was to put one on.
Old Nov 20, 2004 | 09:43 AM
JChan's Avatar
By the way, only other mod I will be doing besides the Y-Pipe is a JWT Pop Charger.
Old Nov 20, 2004 | 10:23 AM
Harvs94max's Avatar
Dont do it little gains and it will sound like crap.
And mother earth will tell the big guy to strike you with lightning. Yikes
Old Nov 20, 2004 | 10:49 AM
RA030726's Avatar
I'm nutty for Nissans
a test pipe is for dyno tuning with a wide band O2 sensor. Dont use it for daily use.
Old Nov 20, 2004 | 09:12 PM
Aaron92SE's Avatar
NWP Engineering.com
I've tested my testpipe at the track. And people who know me, know how consistant my times are since I'm heavily into bracket racing. People are usually right when they say it won't help much. I wouldn't recommend other people doing this b/c your exhaust will sound like crap, you'll hurt the environment, and you will lose low end power.
But, I have a testpipe on my car b/c I see a .08 to .12 gain in the 1/4 mile for only $35. That is the ONLY reason I have one. My exhaust does sound like crap and I did lose low end power.
Old Nov 20, 2004 | 09:42 PM
MaXtUneD's Avatar
Your best bet would be is an electric cut-off pipe...look into one..
Old Nov 20, 2004 | 09:44 PM
Aaron92SE's Avatar
NWP Engineering.com
Yes, I agree. You mean much like the one I have?
Old Nov 22, 2004 | 05:44 AM
98maximaSS's Avatar
what the hell is that thing?? ^^^
Old Nov 22, 2004 | 06:00 AM
Scope's Avatar
Im izz sexay
Electronic Cutoff.
Old Nov 23, 2004 | 06:06 AM
Shadow's Avatar
Unless you're boosted, don't bother.
On a non turbo car, you'll see a few hp, and the exhaust will sound like crap. I swapped out my cat for a 3" test pipe (full 3" mandrel exhaust also) and picked up 34 whp on the dyno, but that was because I picked up a couple of pounds of boost that the stock cat was restricting. I had to add a resonator because my car was sounding so bad though.
Old Nov 23, 2004 | 06:12 AM
SonicDust187's Avatar
I have a budget ypipe, budget straight pipe and greddy sp catback and my exhaust is quiet and sounds good. I did pick up a lot of extra lowend and midrange power becuase my stock cat was clogged after 100,000 miles.
Old Nov 23, 2004 | 05:32 PM
Triple8Sol's Avatar
I miss the .org!
For the price, why not?
Old Nov 26, 2004 | 01:35 PM
Vyrus's Avatar
Just installed my testpipe today. I have a 2.5" mandrel y-pipe, b-pipe, a Magnaflow resonator and a Apex'i Dunk muffler.
I only took it for a quick spin so if the ECU needs to adjust for any reason, it hasn't done so yet.
I didn't notice any gains on the butt dyno, high end or low end. On the same note, I did not notice any losses on the butt dyno, high end or low note. The exhaust has a minor leak I hear hissing from the test pipe, will tighten her and take for another spin later.
The sound is... horrible. It's definitely higher pitched, and very raspy. I dare say it sounds like a 1.6L Honda motor with a can on the end. Before my Maxima has a nice deep growl, very pleasing to the ears at all RPM. Now its flat out disgusting.
My $.02.
-Cyrus
Old Nov 27, 2004 | 07:23 PM
Aaron92SE's Avatar
NWP Engineering.com
My $.02.
-Cyrus
1234567890
Old Nov 30, 2004 | 12:18 PM
Flava_24/7's Avatar
Boosted Panda
I have a straight pipe as well. I put it in after my cat died. Pieces were loose inside of it.
Ive noticed NO gain. Its paired up with a Budget Y and Apexi WS exhaust.
Mine isnt very loud though but it does stink! I think I have a small leak where it meets the b pipe. Ive tried like h#ll to get it to seal but I have had no luck.
OEM cat is definitly the way to go. Dont even consider a hi flow cat, if you have a aftermarket y pipe and the the 2 precats are removed the OEM cat is not very restrictive. Not enough to worry about.
Old Nov 30, 2004 | 01:09 PM
I30tMikeD's Avatar
Where did you get the 3" test pipe or did you make it?
Old Nov 30, 2004 | 01:49 PM
Shadow's Avatar
I had it made, just took it to the same guy that made my 3" mandrel exhaust. But I think Thomas, SX7R sells 3" resonated test pipes.
Old Nov 30, 2004 | 01:59 PM
I30tMikeD's Avatar
Thanks. I will be needing one in the near future
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
