question on clutch/flywheel setup
Old Dec 9, 2004 | 08:45 AM
MaXtUneD's Avatar
Who here has an aftermarket clutch on a stock flywheel??
Any tranny problems you ran into??hows the feel of the clutch??
Reason i'm asking is because I need to put in my transmission soon as possible, and I will be buying the spec stage 2 clutch for my 3rd gen..I wanted to get the fidanza flywheel but Its not possible for me to wait 3 weeks to get it..
Old Dec 9, 2004 | 12:30 PM
DAREN's Avatar
i had a spec stage II and it worked great. it ran strong for 60k miles without a hitch. the only reason i am not still using it is that the vehicle was totalled. the kit will not work properly without a pressure plate that has a high clap load. do not try to use the kevlar disc with an OEM pressure plate. my only regret is that the Spec stage II makes the clutch pedal a little firmer than i would like. i drove the car daily for a while and it felt "normal" its not unil i got behind the wheel of maxima wth a stock cluthc that i realized how firm it was.
Old Dec 10, 2004 | 06:19 AM
cardana24's Avatar
Blown
I am running the ACT/Fidanza set up, and over all I am happy. The only complaint I have is that the Fidanza causes a shutter that has been well document on the org. If you do not rev it up high enough when taking off it will bog/shutter. Other than that this combo has not had a problem putting down my ~300hp.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
