Quick and easy question.
Old Dec 12, 2004 | 10:50 AM
MDeezy's Avatar
Where can I get the tube that is used to bleed brakes/clutch? I went into auto stores asking but they pointed me to some tool, I just want the tube, it should cost lik $.50 but cant find one, and dont know where to get one.
where can I get one that will fit good?
Old Dec 12, 2004 | 11:06 AM
Terran's Avatar
Go to home depot. You should look at the nipple on the bleeder screw first to get the right size. I want to say 1/8" interior diameter, but I'm not sure.
Old Dec 12, 2004 | 11:40 AM
MDeezy's Avatar
thanks for the info, and I should ask them for such a cable? or should go to a specific section and look for something particular
Old Dec 12, 2004 | 11:54 AM
Terran's Avatar
I think it was near the plumbing section. It's just clear plastic tubing. I'm sure its meant for something else so they won't know what you're talking about if you ask for brake bleeding tubing. You will probably have to get much more than you need, but it shouldn't be too expensive anyway.
I just found mine. the tag says clear vinyl tubing. It's 1/4" outside diameter and 0.17" inside diameter. It came in a 10 ft long piece.
Old Dec 12, 2004 | 12:01 PM
Loe max's Avatar
Medical supply store has them also
Old Dec 12, 2004 | 12:22 PM
MDeezy's Avatar
funny you say that at work, a friend of mine (drives a del sol) suggested getting one of the catheter tubes and use that but they looked a little small.
Old Dec 12, 2004 | 01:20 PM
njmaxseltd's Avatar
You can use vacuum hose, get a foot at any auto parts store.
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
