Viper Locking/Trunk problem
Old Dec 15, 2004 | 10:21 PM
djshawnee's Avatar
Hey everyone... I am having a problem with my Viper security system. Whenever I press the lock button on the remote, the security system engages (it makes the "BEEP" sound), but the doors don't lock. If I lock the doors manually, though, the unlock button on the remote works. What could be causing the unlock feature to work, but not the lock function? I got it installed at Circuit City... should I take it back to them and ask them to fix it?
My 2nd problem is that the Trunk release button doesn't work. When I press the button on the remote, the trunk makes a different clicking sound (different than usual), but does not open. This same thing happens if I push the trunk release button on the driver's door (the trunk clicks, but it does not open). If I use the key on the trunk though, it works. This happened last week, and I put some WD-40 on the locking mechanism on the trunk and it made it work for about a day.
It is pretty cold here now... could this be the cause of any of my problems? Anyone have any thoughts? Thanks!
Shawn
Old Dec 15, 2004 | 10:31 PM
Conrad283's Avatar
I need a truck
For the locks, I do believe that it's because of the cold. For the trunk, you have to hit the button a couple of times because the latch isn't working too well.
Old Dec 15, 2004 | 10:47 PM
djshawnee's Avatar
The lock does seem to intermittently work... so you are probably right about it being the cold weather. The power locks with the real switch work fine though. But the trunk latch, I have tried pressing it repeatedly, with no success. I would think that this is also because of the cold, but it's not like it's THAT cold... like 15 degrees here (and it's been through other winters). Any ways to fix?
Old Dec 15, 2004 | 10:53 PM
Conrad283's Avatar
I need a truck
You could always get a new latch from a junkyard and see if that really is the problem.
Old Dec 15, 2004 | 10:56 PM
Maxima99SE's Avatar
will fly for food
sounds like the valet switch on the trunk is flipped, open the trunk with the key and look in the opening where the trunk latches, there should be a switch there, toggle it and youre done... as far as the lock/unlock.. i have no idea.
Old Dec 16, 2004 | 01:09 PM
djshawnee's Avatar
wow i didnt even know that there was a valet switch on the trunk.... fixed that problem. also, it is warmer out today, and the lock button seems to be working.
Old Dec 16, 2004 | 01:14 PM
Maxima99SE's Avatar
will fly for food
glad you found it
Old Dec 17, 2004 | 12:48 PM
Max96GLE's Avatar
Huh! Locks malfunction due to cold weather? This is new to me. If this is true, than forget about Viper. I thought Viper is one of the best. Why would it behave like that in cold weather? The temperature could be 45 degree and it went down to 10 degree. Next thing you know, all the door unlock.
Old Dec 19, 2004 | 11:11 AM
sunten1
i know why it doesn't work it happen to me. Go back to CC and tell them that they have to fix it. For me it was becuase the remote/brain not sure which one has to be set to double pulse or somthing along those lines....
Old Dec 19, 2004 | 11:14 AM
Conrad283's Avatar
I need a truck
No, when it's really cold out all the locking components get stiff. It was so stiff the other night that I couldn't lock the door with my own hand when I got in my car, but then it warmed up and I locked the door with no problem.
It has nothing to do with the alarm.
Old Dec 19, 2004 | 10:24 PM
Nismotic's Avatar
Always sunny in philly
it was really cold today, which froze my doors closed (took a bit to open them) and my windows would not roll down.
Welcome old man winter
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
