I see a small crack....
Originally Posted by minsbang
crrraaapp. I'll stick a bandaid for now.
btw, how much is it to replace the front glass? (parts and labor)
I don't think that will help. You need to drill a very small hole at the end of the cracks to stop the propagation of the crack. then seal the crack with some type of silicone to prevent it from filling up with dirt.
If the crack length is only abou 3/4", I believe most windsheild chip repair places will be able to fix it.
Originally Posted by C MAX
take some crazy glue, the original one and put some at both ends of the crack inside and out, and it will stop that crack dead in its track.
Originally Posted by dmontzsta
hehe, you dont want to see mine, it runs from the drivers side to the passenger side, straight through the middle.
me too, I have a bad crack, it was mainly on the passengers side until one night driving home it was very cold and the windscreen was frosty and I couldnt see, I turn the heat on to the windscreen (about 74 degrees, and it was about 40s outside) All I hear was crack, CRACK, I saw that crack shoot accross to the driver side I immediately turn off the heat and hasnt turn it back on since for the windscreen. . . I need a whole new one
IMHO it won't. But I'm not an expert windshield repair person either. And if he puts a bunch of glue in the crack, how is he going to get it repaired?
I recommend he just get it done right the 1st time. It's not much of a cost (if any if he's insured). And it might take 10 min for the guy to do it. The important thing is he should get it fixed asap before the crack gets too long to be able to get repaired.
IMHO, the only way to prevent a crack from propagating is to stop it. The only way to do that right is to drill a small hole at the end of the crack.
jeff serious it works until he can get it changed or repaired professionally. it will keep it from spreading.
jerrod99_se-l
Sep 25, 2015 03:02 AM
