Need help from the people who have a A/F gauge!
Old May 1, 2001 | 02:48 PM
Synki's Avatar
I just got my Autometer Phantom A/F gauge, i need to know which wire to tap into the ECU. There are 3 wires, ignition, ground (to battery), & a violet color one for the 02 sensor. Can i tap this wire into the ECU for the 02 sensor reading? Let me know ASAP.
BTW, i bought the autometer dual gauge pod for the 300z. I was told that this will fit w/ minor work. Anyone else use or have this? Thanks.
Old May 1, 2001 | 03:00 PM
1MAX2NV's Avatar
Hmm..Why didn't you buy the Maxima pod? It's like $19.
Old May 1, 2001 | 03:15 PM
Synki's Avatar
Doh! Oh well... either way it still works.
Old May 1, 2001 | 08:15 PM
Synki's Avatar
Ok, i need answers. I think ill move this right back up top.
Old May 1, 2001 | 08:23 PM
BrokenMotor's Avatar
yes, you tap the purple wire into the ECU harness, i forgot which one you tap into, but SX7R got my service manual, IM him on AIM, he should know which one you tap into.
Old May 1, 2001 | 10:45 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
aiya, the Z pod will fit but wont look rite, ask Lyt97SC, he had the Z pod before and it looked funky
Old May 2, 2001 | 06:34 AM
Synki's Avatar
Yea, when i get some extra cash i will buy the one for the Maxima but right now it looks fine. I used a heat gune and molded the edges so its contour to the Maxima pillar and it looks fine. I was told i am better off tapping it from the sensor itself rather then the ECU? Can this be right?
I can never catch Thomas when he is on AIM, he is always away or sleepy.
Old May 2, 2001 | 02:26 PM
Synki's Avatar
I'll bump this up again. Maybe someone will see this.
Old May 2, 2001 | 02:40 PM
MardiGrasMax's Avatar
Use a voltometer to trace the wire from the ECU harness to the 02 sensor harness. Its a black wire on the sensor, it turns into a white wire on the under hood harness. The under hood harness's are very easy to access their right at the top. Disconect the ECU harness & batters neg cable, and use the continuity check setting to trace the wire back to the harness from the under hood harness. Its an easy job.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mkaresh
Mar 12, 2018 06:48 PM
REDinLV
Sep 28, 2015 12:31 AM
