Coil over weight VS spring and shock?
Old Mar 22, 2005 | 08:56 PM
krismax's Avatar
Father of the 00 VI
Has anyone weighed the two to see the diff, iam very interested. I would like to see a spring and shock or strut weight VS a real coilover setup.
The spring and shock can be aftermarket,i have tokico and H&R springs and im wondering what going with a good set of coilovers will do for loss or gain weight wise.
My car with this setup is higher than stock and sooner or later i will need a good setup .
If you have info please post if not please no guesses.
Old Mar 22, 2005 | 10:22 PM
japmaxSE's Avatar
Go Get a Life!
I weighed my Eibach coilovers with KYB struts there 6.5 lbs did'nt weigh the stock spring and shock my coilovers feel alot more lighter than factory spring&shock setup thats a fact I picked both of them up, sure is lighter..
according to this site coilovers vs stock will save you 34 lbs
http://lighter.maxdes.net/
Old Mar 22, 2005 | 11:05 PM
Ceasars Chariot's Avatar
Old Maxima Legend
im also interested in this info as well. bump !
Old Mar 23, 2005 | 03:11 AM
Larrio's Avatar
The Definitive AE Master
IIRC my coilovers weigh 45-50 lbs. total
Old Mar 23, 2005 | 10:54 AM
95CustomMaxima's Avatar
I removed my GC Coilovers recently to switch to Tein S Techs.. There is definately a weight difference between the two boxes.. I would say maybe 10lbs.
-Nick
Old Mar 23, 2005 | 11:25 AM
Broaner's Avatar
2060lbs and falling...
Japmax, 6.5lbs seems very light. Did you trim the spring seat off? I imagine thats a good pound or two but the stock system is at least 10lbs.
I'm also getting pretty bad on the rideheight situation. I'd like to get some Coilovers sometime this summer. But I have to get brakes too and get this blower running. Which first? Looks or performance?
Old Mar 23, 2005 | 01:00 PM
krismax's Avatar
Father of the 00 VI
so no one has any good before after weights of jics or teins or d2's?
Old Mar 23, 2005 | 01:09 PM
Matt93SE's Avatar
STFU n00b!
I can't quote numbers, but I'm sure that any REAL coilover will be somewhat lighter than the facotry equipment.
my Eibach ERS springs weigh just a couple of pounds each, and the factory ones are at least double that.
several companies on the coilovers use aluminum shock bodies and spring perches. the factory steel stuff is basically twice the weight on those parts, but all the systems (except the FLT-A2) still use a 3/4" steel shaft through the middle, and a couple hundred mL of oil in the shocks.
I've seen Tein RAs and HAs for an S14 and they both still use a steel body on them (I'm sure the Maxima ones will too), so weight savings will be much less there.
Old Mar 23, 2005 | 01:15 PM
maxspeed96CT's Avatar
The original VQ...
i noticed my tien basics felt lighter than stock ...i have no number for you guys tho, srry.
Old Mar 23, 2005 | 01:56 PM
SamT's Avatar
JIC FLT-A2
front 13.5 lbs. each
rear 10 lbs. each
Old Mar 23, 2005 | 07:43 PM
Old Maxima Legend
someone do the math , lol what do we know so far ?
Stock Springs ___ lbs each (front) ____lbs rear
Stock Shocks ___ lbs each (front) ____lbs rear
_________________
Larrio -
IIRC my coilovers weigh 45-50 lbs. total : larry can you break this down ?
_________________
95CustomMaxima - do you still have these to put on a scale ? (GC Coilovers)
_________________
SamT
JIC FLT-A2
front 13.5 lbs each - rear 5 lbs each (?)
____________________
japmaxSE - not sure what you have ?
___________________
Old Mar 24, 2005 | 04:47 AM
BEJAY1's Avatar
Conecarver
FWIW, my Progress are 55lbs total with mounts & plates. (16lbs front, 11.5lbs rear ea). IIRC they were like 9lbs less than stock. If I get to swapping this weekend I'll weigh the stock ones.
Old Mar 24, 2005 | 06:59 AM
Larrio's Avatar
i'll have to see when I get another set in. That way I can weigh it before installation
Old Mar 24, 2005 | 12:07 PM
japmaxSE's Avatar
Go Get a Life!
sorry I forgot to mention I trimed some uneeded metals and the upper and lower support mount that bolts the top of the shocks I used the part that came with the kit which is alot lighter it's alluminum. (Eibach Ground Controls) Sorry for the poor detail but that's the best way I can decribe it.
Old Mar 24, 2005 | 03:10 PM
JClaw's Avatar
Performance. I bought a 3.5, headers, and lots of sh*t, but I'm still riding on stock sawblades with stock springs/struts
user 11122324
42
Jul 18, 2022 03:35 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
zmcneely13
Sep 26, 2015 02:26 PM
