are there shocks that adjust the ride height ??
Old May 7, 2001 | 06:55 PM
_DRU_'s Avatar
i read that someone had koni adjustables with intrax springs. the intrax springs had a tendency do sag the rear of the car a little so he set the rear konis to the highest setting then the fronts to the lowest settings. does this acutally adjust the ride height or ride quality? if they do affect the ride height, do you know which ones give the widest range? thanks
Old May 11, 2001 | 05:28 PM
Micah95GLE's Avatar
No. Springs determine the ride height. Dampers only control the motion of the springs. Adjusting the damping on adjustable dampers only increases or decreases the stiffness. It doesn't make the damper stick out any more than it normally does.
tarun900
19
Dec 20, 2021 06:57 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
leatherneck
Sep 30, 2015 09:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
