Help CEL code PO171 and P0174
Old Apr 12, 2005 | 02:18 PM
EZEMaxima's Avatar
Okay, i already check what it meant. Both the front and rear bank oxygen sensor showing lean condition. I checked both O2 sensors and they are fine. I changed the fuel filter less than 5,000 miles ago. The car run fine but seems it's alittle sluggish at times. Sometimes my idle drop to about 500 rpm, i'm thinking i might have a vacuum leak. I haven't tested it yet. I also hooked up the scanner while driving and noticed my timing would advance to about 43 on cruising but under full throttle it's only around 27. Anything else should i checked.
Eric
Old Apr 13, 2005 | 07:37 PM
nismo2020's Avatar
Needs non-Maxima Friends
have you replaced the knock sensor before? i had a bad knock sensor and got those codes but once i replaced the ks everything was fine.
Old Apr 14, 2005 | 03:40 AM
EZEMaxima's Avatar
I have one in my closet but never did changed it because my hand couldn't fit in the small opening. I got a few cuts before i could even get my wrench in there. I already picked up a set of 02 sensor both for the front and rear bank but I'll try to change the knock sensor first and see what happens. If all goes well, I'm installing my Apexi VAFC II to activate my MEVI and allow some fuel adjustments with it off or on. Then maybe some track time on Friday!!!
Eric
Old Apr 14, 2005 | 05:55 PM
nismo2020's Avatar
funny i posted on this thread .. i got cel yesterday ..
Old Apr 16, 2005 | 05:29 PM
EZEMaxima's Avatar
I changed the knock sensor and both the front and rear bank O2 sensor and so far it's working good. I'll be installing my VAFCII next week if the check engine lights doesn't come back on.
Nismo20200
Sorry to hear that your check engine light is on. I never BACHI you.
Eric
Old Apr 22, 2005 | 06:40 PM
EZEMaxima's Avatar
the CODE P0171 keeps coming back, the car runs fine, I will have to check for lntake leaks. I also had the P0300 code which is a random misfire and so far did not come back. I'm thinking coil packs are going bad but why would this cause it to become lean instead of a RICH condition. Would the EGR be related to this problem?
The scanner im using also shows te the MAF is in good condition.
Eric
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
