Suspension and steering guys/gals, I need your help
Old Apr 12, 2005 | 03:19 PM
MacAlert's Avatar
I've been having problems with my car for over 2 months now. It involves the steering/suspension. When driving on a straight road and hitting slight bumps, my steering wheel drifts all over the place. This is not your normal bumpsteer. Even when driving on a moderately smooth road, the steering wheel seems to move left/right on its own causing me to have to correct the steering. I was told once by njmaxseltd that I should check my tierods. I did this by jacking up one side at a time. I then proceeded to put pressure on the wheel from one side to the other. Both wheels seemed to move a considerable amount. Now I know what a broken tierod feels like because my dad's van has one. But is this a sign of loose or bad tie-rods or is it something else? Please respond soon cause I will be taking it to my mechanic tomorrow. Thanks in advance.
Old Apr 12, 2005 | 03:50 PM
NmexMAX's Avatar
dot dot dot ...
I was going to say tie rods too, I fixed mine on my old 4g, and it's so much better now, only thing is that's 10 years old, and yours is barely 2 years old. It's possible to have a loose one and not completely dead.
Old Apr 12, 2005 | 04:01 PM
MacAlert's Avatar
Exactly my question. The Nissan dealer says it's not possible but every symptom I have is tied in with tierods (no pun intended).
Old Apr 12, 2005 | 05:53 PM
MacAlert's Avatar
Anyone?...
Old Apr 12, 2005 | 09:26 PM
MacAlert's Avatar
Someone please help me!!
Old Apr 12, 2005 | 09:28 PM
2 Da Max's Avatar
my friend has a 1995 legend with a bent tie rod on the passenger side, the car pulls to the right alot, even after an alignment
Old Apr 13, 2005 | 05:45 AM
njmaxseltd's Avatar
I already helped you, and a few others told you the same thing.
Go have your front end checked for loose tie rod ends.
Make sure you get an alignment after there installed.
Old Apr 13, 2005 | 10:29 AM
maxgtr2000's Avatar
KH3 by popular demand
What about struts, could it be possible that they are completly blown to when you hit a bump, the spring rebound detemines sway of the car? What about the front sway bar and the bushings on it? Wheel bearings? Just swiping in the dark here...
Old Apr 13, 2005 | 12:28 PM
MacAlert's Avatar
I have brand new struts. It was fine one night. Left it covered in snow for two days. Cleaned it out, drove around, noticed problem. Doubt its struts.
Old Apr 13, 2005 | 12:33 PM
mzmtg's Avatar
Minister of Silly Walks
Loose tie rods or ball joints.
Excessive toe-out can also cause a wandering feel.
Old Apr 13, 2005 | 12:47 PM
Sammzway's Avatar
I have the same damn problem man. Steering feels so damn loose. This started happening to me after i installed my new rotors. Plus i think i got bad bearings as well.
Old Apr 13, 2005 | 01:06 PM
bigEL's Avatar
Snow plows could have pushed against your wheels, bending the tie rods.
Did you get an alignment after your new struts? The weight of the snow could have caused your suspension to settle unevenly, throwing off the earlier alignment.
Over inflated tires can produce the effect you describe too. Doesn't sound like a steering rack problem. Good luck.
Old Apr 13, 2005 | 03:20 PM
MacAlert's Avatar
Well, went to my mechanic today. The diagnosis, as njmaxseltd said is the inner tie rod on my left side. Getting the tie rod replaced and getting another alignment done.
And to answer begEL's question, yes I got an alignment after I had new tires and my drop done. I am also running 35psi on OEM 17" wheels with 235/45/17 tires. Also, I never park my car on the street so a snow play could not have plowed against my wheel, and the rare occassion I do park it on the street, the plows have never gone by.
Old Apr 13, 2005 | 04:31 PM
MacAlert's Avatar
Forgot to mention, thank you njmaxseltd for your help.
Old Apr 13, 2005 | 04:38 PM
krmaxima's Avatar
how much did it cost u??? do get it fixed
Old Apr 13, 2005 | 04:39 PM
MacAlert's Avatar
I have no idea how much it is to fix it. I'm going back on Tues to get the tie rod and alignment.
Old Apr 13, 2005 | 04:41 PM
MacAlert's Avatar
There's your problem right there.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
