Apexi VAFCII wiring
Old Apr 24, 2005 | 12:57 AM
EZEMaxima's Avatar
Apexi VAFCII wiring
Does anybody have the wiring color designation for the Apexi VAFCII. I just got a used one and I need to know what each wire is for to install it. I already saw the wiring for the AFC, but the VAFII has the wire to activate the VTEC ( i plan to use to activate my MEVI) and a wire for the Konck sensor. And there is a few unused wires too. I tried to PM my seller but he has not responded yet.
Thanks,
Eric
Old Apr 24, 2005 | 06:47 AM
I30tMikeD's Avatar
A S-AFCII has a kncok sensor wire also. I imagine it is the exact same way plus tapping another wire for an rpm signal.
Old Apr 24, 2005 | 06:05 PM
BSwithTF's Avatar
Sorry man, I thought I'd sent you a PM. The pink wire, IIRC, is for the VTEC activation. It's a 12V out. I had it wired directly to the vacuum switch on the manifold. No relays. The VAFCII doesn't have a hook up for the KS. The purple wire is VTEC associated on it. I've been trying to find the wiring booklet cause it's got all my little notes in it but haven't had any luck.
Old Apr 25, 2005 | 06:41 PM
jmeister's Avatar
Just download the .pdf off apexi website. Shouldn't need the purple wire, it's for the VTEC solenoid input to ECU which you don't have.
Old Apr 26, 2005 | 04:19 PM
EZEMaxima's Avatar
Thanks for the help guys. I'll have too wait to get the VAFCII installed. I have to get my car running right first. I'm still getting the P0171 code.
I'll download thepdf file fro Apexi
Eric
Old May 15, 2005 | 11:02 AM
EZEMaxima's Avatar
I got the VAFCII installed last Friday but I have a question. Does it have the wire for the O2 sensor? What are the light blue and dark blue wires for? Does anybody have the wiring schematics for the VAFCII? The only thing Apexi had on their website was the operating/set up manual for the VAFCII.
I still have the PO171 code and everything is still set to flat setting on the VAFCII. I'll fine tune it after getting rid of the code. I have it set to open the MEVI at 5400 rpm.
Old May 16, 2005 | 09:20 AM
jmeister's Avatar
Wiring schematics? The .pdf instructions/setup should have what each wire color is. Not at home so I can't say off hand what color is what but it's in the .pdf
Why are you opening the MEVI so late? Thought the DE-K VI was around 5200 and the MEVI was around 4600? You dyno tune yet?
Old May 17, 2005 | 12:27 AM
EZEMaxima's Avatar
No dyno tune yet. I set the MEVI at a very conservative 5400 rpm point due to the fact I still have the P0171 code which means "Fuel INJ Sys Right bank:lean"
I've located a website that had the installation manual available in .pdf file but it was not in the Apexi website.
Thanks Eric
Old May 17, 2005 | 08:27 AM
nismology's Avatar
You've got it backwards.
Old May 17, 2005 | 10:45 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the de-k does open at 5200. the 3.5 manifold opens more towards 4000. i am not sure when the mevi typically opens because i do not have one but i thought most were setting their rpm switches to around 5000.
Old May 17, 2005 | 03:08 PM
nismology's Avatar
Are you sure? Everything i've read, including driving my brother's '01 SE leads me to believe it opens before 5000 RPM. Maybe i'm wrong.The ideal MEVI opening is around 5300 RPM.
Old May 17, 2005 | 04:33 PM
sloppymax's Avatar
have his dynoed and it will show up. my first dyno should still be in the dyno forum as well as a few others showing the 5200 crossover.
Old May 21, 2005 | 02:27 PM
EZEMaxima's Avatar
I have been playing around the setting to open and close the MEVI, right now i have it open at 5000 rpm and closes at 4800 rpm. This setting so far gave the best butt noticeable difference. I still have to figure out what is causing my check engine light to go on since car is running good. I checked my sparkplugs and they look fine, no signs of detonation or leaning. I'm beginning to think i might have a short on my O2 sensor wires.
Eric
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
