Help!! Grouncontrol coilovers?
Old May 13, 2001 | 09:50 AM
SINYMaxSE's Avatar
Finally, A New Status Title...How About Donating Maxima.org Member...Oh wait...NO!!!
anyone have these? opiniions, problems i should know about them, recommendations... do i need to buy anything else to have them installed?
Jules
Old May 13, 2001 | 10:53 AM
AznWontonboy's Avatar
Jules
keving..
Old May 13, 2001 | 02:51 PM
SleeperSE's Avatar
Stuff
- As far as I know, you just need to get the springs (yes, they come with the height adjuster). Obviously, do the shocks at the same time unless you already have aftermarket ones on. If you keep the OEM shocks, they'll fail after a while due to the added stress of a lowered car.
- The springs fit in just fine, from what I understand - its the shocks that are hard. You have to modify the stock strut housing to make everything fit. I'm going with a Ground Control/Koni setup this Fall, but I'm having a shop with aftermarket Nissan experience do the installation. If you get it wrong, your suspension will be noisy or it could break.
- Good Luck
Old May 13, 2001 | 06:48 PM
Nealoc187's Avatar
SLOW
i have them
i have ground controls. make sure and cut 3/4s of the bumpstop in the front... 1/2 is fine in the rear. also, with my KYBs, i had to grind a bit of the strut housing down with a wheel to get the sleeve to fit over it. after 5-10 minutes of grinding they fit perfectly. i wouldnt suggest slamming the car all the way down, unless you like bouncing down the road... and make sure to cut THREE FOURTHS of the front bump stop off... 1/2 of it just doesnt work, you wont have enough suspension travel, even if you only go down like an inch and a half to 2 inches.
Neal
Old May 13, 2001 | 07:45 PM
SINYMaxSE's Avatar
thanks
for all the info folks, its appreciated. for those who replied, how long have you had them on? any problems ride wise?
Old May 13, 2001 | 11:38 PM
Nealoc187's Avatar
SLOW
GC
I've only had mine on about 3 weeks now. the ride is stiff, but not super harsh or bouncy for me, as i am only down about 1.75 all around, and i cut my bumpstops properly. IF you slam your car all the way (like 2.75-3 inches) it will be bouncy, no getting around that, cuz you will have virtually NO suspension travel in the front. even if you totally removed your bumpstops, you'd have only about 1 inch of travel... and would just bang metal spring perch into metal strut housing... i would hate to hear that... or feel it.
Neal
Old May 14, 2001 | 12:17 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
ive had my Ground Control/koni setup for over a year. Ride is stiff and i get sick of it sometimes. I lowered it about 2.75 all around. Planning to get the Koni's shortened or see if camber plates will offer enough extra suspension travel.
Old May 14, 2001 | 06:27 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Spell my name right Wonton Boy!
I've had the GC's and Koni's for about a week now. My car is lowered about 2.5" more or less. The ride is stiff and bumpy but not too bouncy. Make sure you cut more of the bumpstop as Nealoc187 suggested.
Old May 14, 2001 | 08:55 AM
SINYMaxSE's Avatar
thanks for all the info
everyone.
BkGreen97
Apr 2, 2016 05:47 AM
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
