Radio Out, can't figure out why (already tried Audio Forum)
Old Jun 1, 2005 | 06:35 AM
Capitone's Avatar
Ok, I've tried all the fuses which made sense, Audio, Bat electronic and a few more I can't even remember, but the radio still won't work. My tail lights are fine, my clearance and side door lights are ok too, but the radio still is inoperable.
Any Ideas on what to try next? I even swapped out my after market with the factory that KNOW was good when I replaced it and still nothing. At least now the factory lights up (not the digital window just the *** and button lights), the aftermarket didn't even do that. I've been at this for almost 5 days now....looking on the internet, pulling everything out and putting it back together....I don't know what else to do. Is there something blown?
All help appreciated!
Capitone
Old Jun 3, 2005 | 04:47 AM
ny96max's Avatar
get a DMM (digital multi meter) and test out your 12v constant and 12v acc. lines going to your radio. And if like you said.... all the fuses are fine then you can assume that you have a burnt out wire going to the radio. The solution would be run a fused wire(10amp) off the iginition harness directly and call it a day.
oh and is this an aftermarket unit or a stock unit?
Ant
Old Jun 3, 2005 | 04:45 PM
nismos14's Avatar
§è~® f®ÈÄk
Replace the audio fuse under the hood and you should be good to og.
Mar 12, 2020 12:06 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
