APC Wire Harness and Fuse
Old May 24, 2001 | 10:04 AM
Soulive's Avatar
Well, since I rewired my power cables to sub, I was thinking..
Shouldn't the APC wire harness have a inline fuse since it's drawing power direct from the battery.
Am I the only one runnin' the harness without a fuse?
Old May 24, 2001 | 11:31 AM
Albertt's Avatar
Yes...I did this >>
Actually, the instructions on the package of the APC harness does mention it...
I bought those inline fuse holder and wired them in between each relay and the battery. I inserted 25 amp fuses cuz I figured since the fuses are rated at 30amps, they'd be safe from voltage spikes.
Old May 24, 2001 | 03:20 PM
Enduro's Avatar
Re: Yes...I did this >>
Wow 25a fuse for Each relay? I'm currently using a single 30a inline fuse for the combined relays. Figured that if you ever have both hi/lo beams on at the same time, and are using 100/55 bulbs, then the total current would only be roughly 26 amps. 310w/12v = 25.8a
9aj9
Apr 5, 2020 12:11 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
zmcneely13
Sep 26, 2015 02:26 PM
