View Poll Results: Otto vs Custom Enterprise
Otto
34.04%
Custom Enterprise
27.66%
other (specify)
18
38.30%
Voters: 47. You may not vote on this poll
Newbie’s question – FSTB
Old Sep 30, 2005 | 05:55 PM
  #41
BewstAdd1ct's Avatar
and agreed with d00df00d, the bar helps both, regardless... wether you preload it one way or the other is just personal preference or driving style, bar improves both greatly.
Old Sep 30, 2005 | 06:00 PM
  #42
DrKlop's Avatar
Driving is the next best thing
Appreciate your help guys, installing my FSTB tomorrow
Old Oct 3, 2005 | 12:00 PM
  #43
DrKlop's Avatar
Hey people, finally installed and tested my FSTB
Installation was not as easy as I thought. In order for the brackets to fit perfectly I had to trim both the brackets and the metal on one of the strut towers. After that I covered those spots with clearcoat and only then installed the FSTB
The holes on the brackets were wide just enough for the bolts to fit in. I tightened the nuts to 40 lbs-ft and FSTB bolts to 30 lbs-ft. Fist, wanted to make them tighter but it felt like they were ganna crack - they would probably never crack but I got scared and stopped.
Driving impressions:
Today I took my car for a drive and drove it on highway, highway ramps and bumpy roads. During normal driving I got a slight increase in steering feel. At highway speeds 70 – 100 the increased steering feel is more noticeable. On bumpy roads the car handled better but the ride became a little harsher (I don’t think a passenger would notice this difference though) than before.
Highway ramps is where my FSTB demonstrated the most noticeable difference. Before when I would take a corner at car’s maximum abilities it showed horrible understeer. Now, when I took my favorite “test ramp” I was very pleasantly surprised. Obviously, the car still understeers but now it is much closer to neutral. Basically, if we take understeer of a stock Max as 100% and neutral steer as 0% than the bar decreased understeer buy at list 60 -70% Previously, the fastest speed I could take that ramp was a little under 40 mph with the front tires literally screaming. Today, the needle was at 43+ and the car felt much more predictable.
Bottom-line: I recommend FSTB to everyone who still does not have it.
Thanks to everyone who helped me deciding on which bar to get and explaining how to install it.
Old Oct 3, 2005 | 05:42 PM
  #44
Haibert88's Avatar
I've got a question kind of related to this thread...does hard cornering wear out the ball-joints and all the other links that are connected to the steering system? I know it wears out the tires much faster but what about the steering components? How about bearings?
Old Oct 3, 2005 | 08:29 PM
  #45
d00df00d's Avatar
Old enuf to pick his own gears
Of course it does.
Old Oct 8, 2005 | 10:48 AM
  #46
minsbang's Avatar
Originally Posted by chenzarino
They are all the same get one for 20 bucks off ebay.
Yes, go on ebay and save some money. There is no need to spend over $50 on a bar.
Old Oct 9, 2005 | 11:00 AM
  #47
DrKlop's Avatar
Quick follow up question, guys. Do I need to retighten the bolts after a couple days of driving?
Old Oct 9, 2005 | 12:42 PM
  #48
d00df00d's Avatar
You shouldn't have to.
Old Oct 11, 2005 | 12:13 PM
  #49
tripleGmax's Avatar
no offense, but this is one lengthy discussion on a strut bar......cant wait til you decide on other suspension mods
Old Oct 11, 2005 | 12:30 PM
  #50
d00df00d's Avatar
Well, seeing as how our cars' frames have the rigidity of a thick slice of cheese, it stands to reason that this would be a hot topic.
Old Oct 11, 2005 | 12:31 PM
  #51
tripleGmax's Avatar
haha cheese. true.
Old Apr 9, 2006 | 11:54 PM
  #52
XyNoix-HIC's Avatar
TRIM?!? What do you mean TRIM!?!
Old Apr 10, 2006 | 09:36 AM
  #53
DrKlop's Avatar
The strut towers are not perfectly smooth (as you can see on the lower part of this pic). So when I put the brackets on, one of those uneven spots got in the way and did not let the brackets be in a full contact with the strut tower surface. To fix that, I simply cut a small piece off of each bracket. I also had cut off a small metal thing that got in the way of the bar (driver side strut tower, not shown on the pic).
Sorry, it's been pretty long time ago so I can't describe exactly what I did...
Old Jul 19, 2006 | 12:03 PM
  #54
JUS10's Avatar
Damn, That Was A Lot Of Reading, It Was Good Though...
Old Aug 23, 2006 | 10:31 AM
  #55
EnsignB's Avatar
Is the Otto bar no longer available for a 2002 Maxima?
Thanks.
Old Oct 23, 2006 | 06:00 PM
  #56
super6's Avatar
Originally Posted by d00df00d
Well, first of all, I can't really say much about the performance of the 5th gen bar because.... I have a 4th gen, and I got the 4th gen bar, which IMO is pretty different. The 5th gen still looks like a pretty stout design to me, and I still think it'd be a better alternative than the Stillen bar because it's much cheaper, but since it's designed more like most FSTBs than the 4th gen one, I just don't have enough info to tell you whether it'd be as worth it for the money as the 4th gen one is.
I bought the 4th gen one because it's designed a lot more robustly than most bars we see in the US. Look at how broad the bar is, and look at where the bar attaches to the mounts: It's a heck of a tougher way to mount the thing than those thin attachment points on every single other FSTB for the Maxima:
the 4th gen design looks like its by far the best design, with they made one for 5th gen like that! the 5th gen one is still better than the ebay bars, but the ebay ones are 25 bucks.
Old Feb 22, 2007 | 10:04 PM
  #57
Simon The Noob's Avatar
Greetings and Salutations
I am new here but I like it.
I am thinking about buying a Maxima Diesel.
Anybody know about these fine pieces of Machinery???
Old Feb 24, 2007 | 03:03 PM
  #58
MacGarnicle's Avatar
might want to ask your questions in the 1&2nd gen forum.
Old Mar 31, 2007 | 05:18 PM
  #59
Mugen13's Avatar
Thanks.
i tried buying a otto bar back in may of 06 and procarparts said there would be a 2month wait so i cancelled my order. now that i want it again, its not available. sigh
Old Aug 31, 2007 | 01:22 PM
  #60
BJSE03's Avatar
Nothing like digging up an old post, but FYI.......
I just purchased a NEW OTTO FSTB about 1 1/2 months ago although it was $90. It is really a great bar; nicely finished and fit perfectly.
It seems that there may be still a few available new out there. I don't know if I can post the name of the place which I bought it but if anyone is interested in knowing where, let me know!
Old Aug 31, 2007 | 07:36 PM
  #61
EnsignB's Avatar
I'd like to know where you got it. Been looking for one.
Thanks!
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
